Thread: Objects de-select from selection set in Move command when Zooming in
    2004-08
    131
    Default Objects de-select from selection set in Move command when Zooming in
    Here is the process of the move I am speaking of. While zoomed out, activate move command-select objects-zoom in to pick point-move to new pick/destination point-select destination point.
    Doing this only moves those items inside the zoomed in window.
    This is what one of our Project managers is having a problem with. I cannot duplicate it. I remember something similar happening to me on 2004 but have not have not had it happen lately.
    Is there a setting for that?
    Thanks
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: Objects de-select from selection set in Move command when Zooming in
    I'm not sure if it's the same issue, but you might look at THIS THREAD and see if it helps or not.
    100 Club charlie.bauer341340's Avatar
    2002-05
    Here, because I'm not all there
    141
    Are the lines on a locked layer?
    2004-08
    131
    No the layers are not locked. I think it has everything to do with the previous post to yours. Thanks for the input though.
  1. Creating a command to move objects in Z-axis
    By dortega4269 in forum AutoCAD Customization
    Last Post: 2009-12-30, 03:27 AM
  2. Copy and Move command selection problem
    By smckee in forum AutoCAD General
    Last Post: 2008-09-05, 05:03 PM
  3. Replies: 1
    Last Post: 2007-03-08, 01:12 PM
  4. Replies: 9
    Last Post: 2006-12-06, 03:02 PM
  5. Pre-select objects, issue command - nothing
    By nkennelly in forum AutoCAD General
    Last Post: 2006-01-20, 10:02 PM
