Results 1 to 10 of 10
Thread: AutoCAD 2007 - Plots are too light when plotting a project
    2002-09
    4
    Default AutoCAD 2007 - Plots are too light when plotting a project
    I'm using AutoCAD 2007.
    I'm plotting from the paper space layout.
    I have a project from a fellow coworker that when I plot the plots are to light so I go though the following:
    Plot, turn off the 'plot with plot style', preview the drawing, turn the 'plot with plot style' on, preview , then plot.
    What do I need to reset or do to correct this problem.
    I didn't have the problem till I got his project.
    13,656
    Question Re: AutoCAD 2007 - Plots are too light when plotting a project
    Quote Originally Posted by dlhockman
    <SNIP>
    <SNIP>
    Hi
    Do you have access to the same Plot Style ( CTB or STB ) file your co-worker uses on the project ?
    Have a good one, Mike
    2005-04
    Ireland
    68
    Default Re: AutoCAD 2007 - Plots are too light when plotting a project
    Try thickening the lineweights in the plot style table. If they're set to default, change them to a specific lineweight that you're happy with. He might have the default lineweight set too thin oin the drawing.
    2002-09
    4
    Mike,
    I do have access to the ctbs file. The CTB file is the same file we use on other projects without any problem.
    Steve
    13,656
    Hi
    Ok! Are you the only person experiencing Plotting issues / problems with those particular project DWG files ?
    2002-09
    4
    The fellow worker I got the project from has the same problem with the drawings.
    Design Visualization Moderator stusic's Avatar
    2004-10
    Denver, Colorado
    1,515
    Okay, trying to narrow down the possibilities, so:
    You're plots are too light, so are his.
    You have access to, and are using, the correct ctb file.
    Was the original drawing supplied by an outside source who may have used a different ctb file, or did this drawing originate in your office?
    I don't know that it matters, but is this plot style layer-dependant or color-dependant?
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    560
    Try to post the drawing file (or at least a part of it if it's too large or confidential) along with the ctb file associated to it and let us see if we all do experience the same problem. And we'll try to have our own diagnosis of the file.
    2008-09
    11
    Its not plotting to light.. what its doing is plotting in color and not black.
    I have been having this problem and looking for a solution since the switch from ACAD 2005 to ACAD 2009.
    Its very frustrating.. and has somethign to do with the Visual Styles.. thats my best guess anyway.
    Charles
    2008-11
    I have just set the plot style to monochrome...but not sure what effect it will have on the line types and what have you.
  1. AutoCAD 2007 DWG to PDF plots with Black Bands/Lines
    By Brent.Reeves in forum AutoCAD Plotting
    Last Post: 2011-02-25, 05:06 PM
  2. AutoCad LT 2007 Plots Very Slow
    By djopr in forum AutoCAD Plotting
    Last Post: 2007-08-09, 01:45 PM
  3. Imported Images appear too light in AutoCAD 2007
    By beajohn in forum AutoCAD General
    Last Post: 2006-12-20, 11:38 PM
  4. AutoCAD 2007 Plots slowly
    By drafting1 in forum AutoCAD Plotting
    Last Post: 2006-09-25, 03:34 PM
  5. AutoCAD LT 2007 - Plots incomplete
    By kmabie in forum AutoCAD LT - General
    Last Post: 2006-06-13, 07:22 AM
