Results 1 to 10 of 12
Thread: tangents and lengths
    All AUGI, all the time Richard McDonald's Avatar
    2002-01
    At right angles to reality
    537
    Default tangents and lengths
    More of a how to draw question that CAD Support.
    I have 5 radii with known lengths, I know the orientation of the first arc and all the other arc are tangential.
    Is there any way to calculate the orientation of the other arc?
    13,656
    Default Re: tangents and lengths
    Hi
    If I am understanding ( unlikely ), take a look at the following thread...
    Draw Arc's that are continuous and tangential
    Have a good one, Mike
    2002-01
    537
    Many thanks Mike but those suggestions would either give an approximate length or approx. radii.
    I have a feeling this is an impossible task and require either a centre of end coordinate.
    13,656
    Hi
    No worries...
    Is it possible to post what you have ( and what you need to achieve, end result ).
    2002-01
    537
    Here's roughly what I've been given.
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    2
    The way I check to see if an arc is tangent with another arc quickly is to draw a line from the common endpoint of the arcs to the center of one of the arcs. If the distance from the center of the other arc perpendicular to the line is 0.00, I'm golden. (see attached) This also works for reverse curves.
    I don't know if it will help you or not, but maybe it will give you some ideas.
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    Quote Originally Posted by McDonaldRi
    looks like a spiral in a road alignment to me.
    Lost
    1,473
    Quote Originally Posted by Maverick91
    Ooooo, looking at it again, with the differing radii at each end, you are probably right. That's out of my league. Are there any railroad guys around here?
    <Schultz's voice on>I know not'ing, not'ing, not'ing.<Schultz's voice off>
    I could stop if I wanted to andy.manninen's Avatar
    2015-10
    @ _ork
    304
    The way i would do this is with your first arc drawn, draw your second arc as a polyline, so you have more options, set the appropriate radius and then use the LENGTHEN command to get the arc to the correct length, rotate the second arc to be tangental (the way Tim Creary explained), draw your next arc and lengthen and rotate, ETC ETC..
    does that help? pretty painful and slow, but workable...
    :Cheers:
    1,324
    Quote Originally Posted by timcreary
    I deal with spirals on occasion for alignments for APM systems. When LDT creates a spiral, it's actually made up of ten curves of differing radii, from a real big number down to the something close to the radius of the next circular curve. However, I don't know a way of quickly and easily doing what he wants to do here
  1. Add up line lengths
    By bmckenzie in forum AutoLISP
    Last Post: 2014-01-03, 06:32 PM
  2. how to dimension arc lengths?
    By Mike Y in forum Inventor - General
    Last Post: 2009-04-13, 01:07 PM
  3. Dimensioning-Snaping to tangents
    By jbaysinger in forum Design Review - General
    Last Post: 2008-01-16, 04:22 PM
  4. Label Tangents
    By jeepinaround in forum Civil 3D - Civil Design Companion - General
    Last Post: 2005-12-21, 06:17 PM
  5. Arc Lengths
    By justin.hosler in forum Revit Architecture - General
    Last Post: 2004-12-10, 04:59 PM
