Results 1 to 8 of 8
Thread: Fatal Error: Out of memory
    2006-08
    Pittsburgh, PA
    16
    Default Fatal Error: Out of memory
    I'm running AutoDesk Land Desktop 2005 on XP SP2. When opening specifig drawings, I receive an error message "Fata Error: Out of Memory." Then Land Desktop closes. I had this problem before and fixed it by installting a different build of Land Desktop. However, now I am running this same copy of Land Desktop. Any suggestions??
    Evan
    2006-01
    Land of chocolate
    228
    Default Re: Fatal Error: Out of memory
    check your taskmanager om memory usage when handling this file - see the peak memory usage - is it close to 1,8Gb??
    What is the fysical ammount of the memorybank of your computer??? Setting up the 3GB switch on the boot.ini file might be an option...
    2004-08
    Hartford, Michigan
    3,086
    Quote Originally Posted by evan.haun
    Evan
    try adding more ram memory to your computer, when we had that problem, we were only running 1GB on Vanilla AutoCAD, we upped it to 2 GB and the problem doesn't occur as often, we were just maxing out our resources
    Christopher T. Cowgill, P.E.
    WIGHTMAN & ASSOCIATES, INC.
    ENGINEERING <> SURVEYING <> ARCHITECTURE
    AutoDesk Infrastructure Design Suite Premium 2013 x64
    Windows 7 Pro x64
    2001-03
    13,499
    Hi Evan
    Please note I have *moved* this thread from the AutoCAD General forum to this one...
    Thanks, Mike
    Forum Manager
    2006-08
    Pittsburgh, PA
    16
    I have 2GB of RAM already. But I looked at an early post, when I had this problem before. The problem is the version of Land Desktop. The version in which I receive this error is 16.340.0.129 and the version that works is 16.310.10.92. I have no idea what the difference is between the versions. But I used a program called Aida32 to get the version information.
    Thanks for the replies.
    2006-08
    Pittsburgh, PA
    16
    After installing Service Pack 1, I received the error. My solution, don't install Service Pack 1!!! SP1 changed the version number.
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    SP1 shouldn't cause a problem. In fact LDD 2007 is nearly useless without it - it crashes constantly.
    Sounds like you have some other problem going on. I'm not sure what it could be, though.
    2006-08
    Pittsburgh, PA
    16
    Well, we'll be upgrading to LDD 2007 in January. But we only receive this error when SP1 is installed. If SP1 is installed every machine that has it gets the error.
  1. 2012: Revit mep: Export to dwg fatal error. Sync fatal error as well
    By Scottybill in forum Revit MEP - General
    Last Post: 2012-11-30, 08:47 PM
  2. Fatal error: out of memory?
    By otto2_ in forum AutoCAD LT - General
    Last Post: 2009-10-06, 03:50 PM
  3. Fatal Error: Out of Memory Shutting Down
    By evan.haun in forum Land Desktop - General
    Last Post: 2006-08-14, 09:03 PM
  4. Replies: 2
    Last Post: 2005-11-04, 12:46 AM
  5. Fatal Error: Unhandled Exception" Error Message
    By jkrulicki in forum MDT - General
    Last Post: 2004-07-28, 03:56 PM
