Thread: Survey 2006
    2002-02
    6
    Unhappy Survey 2006
    I work for a University that had an umbrella license for all Autodesk products. I had Autodesk Survey 2006 loaded on my computer to do some co-go work. However when I went to use the software it informed me that I had to have Land Development Desktop loaded first. Long story short, the umbrella license was not renewed for this academic year so I no longer have the legal authority to use the product. In trying to use the control panel to remove the program the same message pops up. How can I remove this software now since I do not have access to LDD?
    I could stop if I wanted to Sammie's Avatar
    2005-02
    Chillin' at Home.
    498
    Default Re: Survey 2006
    Quote Originally Posted by wpalmer
    have you tried doing an uninstall of the program on your computer??
    2002-02
    6
    Yes, I have done it several times and each time I get a dialog box saying I have to have LDD installed before proceeding! Any help would be appreciated.
    Member ksteele's Avatar
    2000-10
    Sunny Northwest Florida
    15
    Did you get a reply to how to UNINSTALL Survey without LDD installed?
    Kimberly Steele
    All AUGI, all the time brian.hailey933139's Avatar
    2006-12
    Loveland, CO
    734
    Knowledgbase article TS45252 will instruct you on how to completely remove all Autodesk software on your computer. This will force the uninstall. Unfortunately, this will also uninstall all Autodesk software.
    HERE
    Autodesk likes to mess with their website every once in a while so the link may not last. Search for the article by number if necessary.
    Brian J. Hailey PE
    CAD-1
    Civil3D PLUS My blog
    At Your Desk Training
    2000-10
    15
    Thanks Brian, been working on this most of the evening, trying to clean the registry UGH! I found a "Windows Install Clean Up" download from a microsoft knowledge base article. Seem to do the trick. All traces of autocad are gone. Now I can do a clean install and not see all the stranded licenses in "Add & Remove Software"
    Kimberly Steele
  1. Survey Module for Civil 3D 2006?
    By Rayllen in forum Survey - General
    Last Post: 2009-03-12, 06:15 PM
  2. Adding "Survey Link" option to Survey Folder pulldown???
    By Civil-Tech001 in forum Survey - General
    Last Post: 2007-12-19, 06:49 PM
  3. Replies: 1
    Last Post: 2006-11-21, 11:40 AM
  4. Revit vs. Autocad 2006 or 2007 Survey
    By mccurdyks in forum Revit - In Practice
    Last Post: 2006-10-11, 08:25 AM
  5. Win XP 64 and 2006 Survey module
    By jpostlewait in forum Survey - General
    Last Post: 2005-11-21, 11:34 PM
