Thread: Recessed wall based fixture
    All AUGI, all the time ford347's Avatar
    2005-01
    Oroville, CA
    867
    Default Recessed wall based fixture
    When creating a wall based fixture that is to be recessed in the wall, do I use a void in the family so it will cut the wall in the project? I can't use an opening because that will cut the entire depth of the wall. I just want the extent of my geometry within my family to cut the wall. thanks.
    Josh
    Revit Technical Specialist - Autodesk Scott Davis's Avatar
    2003-04
    Chino, CA
    4,743
    Default Re: Recessed wall based fixture
    Yes, use a void. Be sure to either set the cut depth of the void, or make it a parameter so you can control how deep it cuts.
    Scott D Davis
    AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
    AUGI Addict truevis's Avatar
    2004-07
    Massachusetts, USA
    1,186
    Here's just a cutout -- a void based in a wall.
    2005-01
    Oroville, CA
    867
    Thanks a lot guys! Answers a lot for me.
    Josh
  1. Electrical Fixture - Wall Based Issues
    By Bike-Ramrod in forum CAD Management - General
    Last Post: 2012-03-30, 06:51 PM
  2. Recessed Wall Based Families
    By mhaidar in forum Revit Architecture - General
    Last Post: 2008-01-09, 10:59 PM
  3. Anyone know where I can find a 2x4 recessed fluorescent light fixture?
    By c_crawley in forum Revit Architecture - General
    Last Post: 2006-01-23, 09:52 PM
  4. Roof based recessed can
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2005-02-20, 01:52 AM
  5. Wall Based Plumbing Fixture: Not snapping to wall
    By Chad Smith in forum Revit Architecture - Families
    Last Post: 2003-09-22, 09:39 AM
