Thread: Multiple Renders?
    2006-09
    3
    Question Multiple Renders?
    Hey Everyone,
    I was just wondering if it is p[ossible to run several renders at the one time using Revit as they are taking up alot of time in the work place. This would make our work more productive as we could set up several views and run a high quality render of it overnight to allow less down time during the day.
    Cheers, Ben.
    AUGI Addict truevis's Avatar
    2004-07
    Massachusetts, USA
    1,186
    Default Re: Multiple Renders?
    It may be possible using the journal file. I tried it once and it kind of worked. If you have the exact same views that you're often rendering, you can record your steps once, save-as the journal file (maybe with edits), and drop that journal on the Revit desktop icon.
    YMMV.
    Obviously would be nice if there was a proper batch rendering tool. Could it be done with the API?
    2003-11
    New Zealand
    1,116
    No, journal files are it. I would recommend MAX/VIZ if you are doing that much rendering. This would allow you to not only batch render but also use all PC's on the network if desired.
    Guy
    2004-07
    Massachusetts, USA
    1,186
    Another way is to make a course walkthrough (high-res) and use the individual frames as your renderings.
    Another way is to start renderings of different views on multiple computers before going home.
    Quote Originally Posted by GuyR
    ...I would recommend MAX/VIZ if you are doing that much rendering. This would allow you to not only batch render but also use all PC's on the network if desired...
    Yeah, could do that, You'd simply have to aquire the software, re-do all the materials, lighting, plantings, etc., deal with DWG export/linking, learn how to use MAX and whatever renderer you use, learn how to setup render farm, administer keeping the model and its materials, lighting, plantings, etc., up to date,...
    2006-01
    4,516
    Someone here made a script, where you write a simple txt file with the file name and the views you want rendered, and you plug it in to a script that pounds out a proper journal file for you. It works great because then you dont have to mess with the journal yourself.
    I (and i suck at messing with code) edited the script so that you could change the output and make it export the rendering via the export in the file menu, instead of the button (more options to export).
    I cant remember where it is on AUGI, but its here. It works great, as long as you take care to prep before running it (make sure there are no conflicts with the instructions in the journal or it crashes...)
    Weve used it on a few projects to make them run overnight...
    The above post is by a user not frequenting the site. Questions regarding post:
    Send to: aaron@aaronmaller.com (include text of post). Thanks.
  1. Structural Renders
    By cholmes in forum ACA/AMEP Gallery
    Last Post: 2007-11-01, 07:05 PM
  2. Jaggy renders
    By fhoffnar in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-08-15, 10:53 PM
  3. First Renders
    By captainbunsaver in forum Revit - Gallery
    Last Post: 2007-03-17, 02:12 PM
  4. Some New Residential Renders
    By jay.80870 in forum ACA/AMEP Gallery
    Last Post: 2006-07-20, 05:01 PM
  5. First Renders
    By Exar Kun in forum Revit - Gallery
    Last Post: 2004-02-20, 05:24 AM
