I was wondering if anyone can tell me what I need to change to solve this problem...
Some of my drawings, (not all) will only let me select any object once.
I then cannot select it again until I have used tilemode to go into paper space clicked into and out of any viewport then gone back into model space.
I can still select multiple objects, but only if I it is the first time I have selected them, any I have previously selected will be excluded from the set.
However if I type a command first then I can select anything fine.
I would like to be able to use grip edit again! - Any ideas?
Running ACAD2004 file format in Autodesk Map.
