I have a site plan with contours with high at the bottom and low at the top of the site plan. The site is a true radius of 100'. The site contours are reading upside down. Any ideals how to fix this?
There is no fix at the moment. Be sure to log this with Autodesk Support.
Revit is designed to have the label for a contour always point it's bottom down the hill. Just the way it is - not the way it should be.Originally Posted by Don Sutherland
Don't drink the Kool-Aid...
Aaron Rumple, AIA
We encountered the same problem and it was maddening until we finally figured out that if you plot directly to the plotter from autocad it will always rotate the contour label upside down, but if you plot from a dwf of the drawing it will print the contours as they appear in the view.
Just ran into this very old one again. Is this still not fixed?
Still not fixed. And it seems to me that it labels from low to high, so if the high point is at the top or left of the screen, you get correct labels. If the low point is there, you get junk. I guess since it isn't sexy to say we fixed the broken bits, this stuff doesn't get funded for development. Starting to get really frustrated with the amount of simply ridiculous stuff that never gets fixed, while Google Earth plugins and the #@$% Steering Butt gets added. Lame.
Then again, you could probably say they need to junk the entire site toolset and start over, so perhaps they are not bothering to fix something they know they will be throwing out soon anyway? Probably Sarbanes-Oxley requires drawing and quartering for telling us anything about it too.
Gordon
Chad the Optimist? Never thought I'd see the day!![]()
As for fixes, I would LOVE to have a ground up re-write, with nothing new, just bugs fixed and code well sorted so improvements moving forward would be easier. And I would defend Autodesk at every turn. Alas, bean counters don't much care for such things, and Autodesk is not the same company they where back when AutoCAD got a ground up re-write. And Pessimist is just a word used by Optimists to describe Realists.
Still, cross my fingers and hope. But I have also spent the last two weeks trying to get a complex site out of Revit, so my tolerance is wearing a bit thin. And my forehead a bit flat and brick textured.
Gordon
No, no. I'm still quite pessimistic about the development of Revit. There's still a lot of mess to tidy up and tools to enable.
I'm just optimistic about the site tools as I've have heard from various sources (including Autodesk) over the past few years that there is something in the works. When it will be released? Who knows, but I'm hoping next release now that Mentalray is out of the way.
This is still annoying...
