Thread: error while moving Vault database to a new location
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    1,901
    Default error while moving Vault database to a new location
    I followed the directions I got from my reseller to move the Vault database but when I try to attach to the database in the new location I get an error (see attachment). The reseller was not sure why I got the error.
    These are the steps I took:
    Stop service
    Detach the Vault
    Move mdf and ldf file to new location using explorer
    Attach Vault to new location
    I moved the database from my local PC to a Windows 2003 server. As far as I know Windows 2003 Server is a supported OS for the Vault so I can't explain the error. Does anyone have any ideas what the problem might be?
    Edit: I am using Vault 5 (build 11.0.118.0) that ships with Civil 3D 2007.
    Jeff Paulsen
    2002-04
    Colorado
    1,901
    Default Re: error while moving Vault database to a new location
    It appears the SQL Server requires the MDF and LDF files to be on the same computer. You can't put them on a network share.
    The MDF and LDF files can be moved to another SQL server.
    Jeff Paulsen
  1. moving Vault database to a different server
    By david.allen728896 in forum Vault - General
    Last Post: 2012-08-20, 03:55 PM
  2. Moving Points and updating point database
    By SJCAN in forum AutoCAD Civil 3D - Survey
    Last Post: 2011-07-18, 07:51 PM
  3. Replies: 0
    Last Post: 2011-03-17, 06:54 PM
  4. Moving Assemblies in Vault
    By Mike Y in forum Vault - General
    Last Post: 2010-05-20, 11:29 PM
  5. AutoCAD Electrical default database location
    By clarkrj in forum AutoCAD Electrical - General
    Last Post: 2007-01-10, 04:46 PM
