Does anyone know how to add trim around a an arch top window that is in a 5'-0" radius curved wall?
Last edited by Wes Macaulay; 2006-11-02 at 09:08 PM. Reason: Please don't post requests for help in the Tips and Tricks forum, thanks.
Is the trim decorative, or just a flat profile?
the trim is very decorative.
You need to make it as a plan extrusion, then a blend void in elevation. So in plan, click extrusion, draw a solid shape the thickness of your trim and make it from your spring point to the top of the trim, then in elevation, use a void to cut the bottom and top off. This gets you a curved arch shape. For the detail you will have to create that as either linework or a sep family that you nest in and copy around as needed.
Scott D. Brown, AIA
Project Coordinator | Director of Building Information Modeling
HHCP.com
Hey Scott,
Would you please post an example?
Patrick
Pat Wm Smith
Here is a quick example showing the process. I do these in place in reality I just cant post a whole model, so this family shows the process. Since you can't curve the wall in a family, you need to make it in place or provide radius parameters in the trim family.
Scott D. Brown, AIA
HHCP.com
