Thread: Where's the table/table styles data
    2002-01
    13
    Question Where's the table/table styles data
    I am attempting to find the folder in which table files/styles are stored so I can create universal tables and put them on a shared drive for use by all technicians. Does any one know where these are?
    Thanks!
    Jose!
    2001-03
    13,499
    Default Re: Where's the table/table styles data
    Hi
    Table Styles are stored within the DWG / DWT file that they are created eg
    Similar to Text Styles, Dimension Styles, etc.
    From AutoCAD Online Help File [F1]...
    Quote Originally Posted by Work with Table Styles
    You can also use DesignCenter to copy table styles from other drawings.
    Have a good one, Mike
  1. Replies: 1
    Last Post: 2007-04-07, 12:39 PM
  2. Insert Block, allow user to enter data, then have the data placed in a Table
    By thomas.stright in forum Dynamic Blocks - Technical
    Last Post: 2006-08-11, 02:40 PM
  3. How to Create Access table data to AutoCAD VBa Combo box data
    By avinash00002002 in forum VBA/COM Interop
    Last Post: 2006-06-20, 08:22 PM
  4. Linking AutoCAD Object Data Table to Access table
    By m.storey in forum AutoCAD Map 3D - General
    Last Post: 2006-05-02, 02:54 PM
