Thread: bad definitions in custom linetypes
    I could stop if I wanted to jgratton's Avatar
    2002-07
    Calgary, Canada
    397
    Default bad definitions in custom linetypes
    Here is a snip of a custom linetype:
    *Pneumatic_Line2,Pneumatic Line2 ----\\----\\----\\----
    A,.9375,[TRACK1,ltypeshp.shx,S=.125,R=45,X=0,Y=0],.125,[TRACK1,ltypeshp.shx,S=.125,R=45,X=0,Y=0],0
    *Sonic,Sonic ----~----~----~----
    A,1,["~",romans,S=.85,R=-18.4349,X=0,Y=0],.5
    They both work as is, but if I try to use txt instead of romans, I get a bad definition error.
    I tried adding .shx at the end, I tried copying txt.shx to the location at top of the search path. I even tried creating a new style in my test drawing that uses txt.shx. The reason I need a different font is because the tilde is too wide, I need the curves much narrower.
    What are my options?
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: bad definitions in custom linetypes
    Quote Originally Posted by jgratton
    Do you have a text style in the drawing called txt? If not, create one called txt that uses txt.shp. You might look at making a shape to add to ltypeshp.shp. I think there are some posts on this in the customization forum.
    2002-07
    Calgary, Canada
    397
    Right you are. I searches a few more phrases and found the help I needed. I had no idea that Express tools had that utility. Now I just need to work out scaling issues and I'm in business! Thanks.
    13,656
    Hi Janet
    Please note I have *moved* this thread from the AutoCAD General forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
  1. 2013: Linetypes now have bad definitions
    By mike.mccall in forum AutoCAD General
    Last Post: 2014-09-25, 11:14 AM
  2. Can someone help with with a few custom linetypes.
    By jmeyer.186809 in forum CAD Management - General
    Last Post: 2010-11-03, 07:56 PM
  3. custom linetypes
    By ndiamo4669 in forum AutoCAD General
    Last Post: 2010-06-28, 11:10 PM
  4. What is the best way to create New Custom Linetypes?
    By tlarocco in forum AutoCAD Customization
    Last Post: 2006-12-13, 11:23 PM
  5. Improved Custom Linetypes
    Last Post: 2006-05-14, 01:46 PM
