Results 1 to 8 of 8
Thread: Missing Shape Files / Select Shape File
    2005-01
    115
    Angry Missing Shape Files / Select Shape File
    When I insert a block, autocad asks me to select a shape file? Why does it do this and how can I make it stop?
    I also get a similar message when I open certain dwg.s asking to select a certain font.
    I have a feeling these are etransmit related.
    Any help would be appreciated.
    2001-03
    13,499
    Default Re: Missing Shape Files / Select Shape File
    Hi
    You are missing a required Shape file(s) OR it is not in the AutoCAD Search Path.
    If you are actually missing the Shape file(s), is it possible to obtain them from the source of the original DWG file(s).
    If you have the Shape file(s), make sure they are stored somewhere within the AutoCAD Search Path.
    Have a good one, Mike
    2005-01
    115
    Not exactly sure how I can go about this?
    2001-03
    13,499
    Question Re: Missing Shape Files / Select Shape File
    Quote Originally Posted by jocques
    Hi
    What do you mean ?
    Without access to the correct Shape file(s) the DWG file(s) are incomplete.
    It is possible to remove the Shape file(s) associated with DWG file(s), but by doing so you remove information from the DWG file(s).
    2005-01
    115
    Makes sense, but I don't know where or how to search for the required files-?
    Mike
    2001-03
    13,499
    Hi
    Did someone send_ you / supply_you_with the DWG file(s) ?
    If yes, try speaking with them first... they should be able to supply you with the missing Shape file(s).
    If no, where did the DWG file(s) originate from that contain the missing Shape file(s) ?
    Have you tried searching your local / network drives for the missing Shape file(s) ?
    Houston
    7,520
    Take a look at: http://rkmcswain.blogspot.com/2006/0...hape-file.html
    Note that shape files and font files share the SHX extension, but they are different and cannot be used for one another. So a prompt for a SHAPE file is something different than a prompt for a FONT file.
    Houston
    7,520
    Quote Originally Posted by Mike.Perry
    Not necessarily.
    Just because a shape file is loaded in a drawing doesn't necessarily mean that shape is used in the drawing.
    A person opening such drawing would be prompted for the shape file regardless of whether there are any shapes actually in use or not.
  1. Replies: 11
    Last Post: 2012-08-21, 02:28 PM
  2. "Undefined shape" but no missing shape file?
    By cheshirecatfish in forum AutoCAD General
    Last Post: 2012-01-04, 03:42 AM
  3. Missing Shape files?
    By akasten in forum AutoCAD General
    Last Post: 2007-11-12, 12:28 PM
  4. missing shape files
    By sumulong in forum AutoCAD General
    Last Post: 2006-03-08, 12:30 PM
  5. Select Shape File
    By Rayllen in forum Land Desktop - General
    Last Post: 2005-07-05, 08:10 PM
