Thread: OSNAP for center of polygon
    ACAD Wish List Administration
    1,920
    Default OSNAP for center of polygon
    Summary: Center of polygon OSNAP
    Description: I would like to see an osnap feature that snaps to the center of a symmetrical polygon regardless of orientation.
    How Used: Fewer picks.
    Feature Affinity: Snaps
    Submitted By: Billy Wooten on October 27, 2006
    AUGI Addict madcadder's Avatar
    Too far from the beach
    1,054
    Default Re: OSNAP for center of polygon
    Until it gets written in stock...
    use: 'average
    You can write it into the POP0 menu...
    ;;; Average point of all selected points
    (DEFUN c:average (/ |average| |count| |nextpoint| |pt1| |temp-pt|)
      (SETQ |pt1| (GETPOINT "\nSpecify first point to Average: "))
      (SETQ |count| '(1 1 1))
      (SETQ |temp-pt| |pt1|)
      (WHILE
        (SETQ |nextpoint|
    	   (GETPOINT |pt1|
    		     "\nSpecify next point or RETURN to end: "
         (SETQ |temp-pt| (MAPCAR '+ |nextpoint| |temp-pt|))
         (SETQ |count| (MAPCAR '1+ |count|))
         (PROMPT
           (STRCAT "\n" (ITOA (CAR |count|)) " points specified: ")
      (SETQ |average| (MAPCAR '/ |temp-pt| |count|))
      (command "_non" |average|)
    2006-12
    Big "D"
    3,711
    Or you could use the mid between 2 points snap.
    Lakewood Washington
    33
    I would change the phrase from center osnap grip to centriod grip. Once the polygone has been changed by streaching the polygone by it's grip making it an arbitrary shape, still a polygone, there is no longer a centroid.
    Otherwise if the polygone is created such as a circle where if you try to change size of the polygone keeping it's symetry in tact at all times then a osnap centroid grip is fesible. This can also be applied to parallelograms.
    5,719
    Instead I use Gile's Custom Osnap plugin... This provides third (TRD), quarter (QTR), centroid (CTR), and Fraction (FRC) snaps.
    2011-08
    4,581
    Exclamation Re: OSNAP for center of polygon
    The wish has already been granted. This thread is closed to further posts.
  1. 2015: Center of object Osnap
    By smcfarren in forum AutoCAD General
    Last Post: 2014-11-14, 06:04 PM
  2. Polygon center
    Last Post: 2014-07-02, 03:48 AM
  3. Center of object OSnap
    Last Post: 2013-03-03, 01:13 PM
  4. Osnap center
    By djones.220368 in forum AutoCAD Customization
    Last Post: 2009-06-18, 09:28 PM
  5. Stretch a Polygon/Maintain the Original Area of Polygon
    Last Post: 2007-08-02, 04:39 PM
