Thread: 4g RAM and the /3G Switch
    NavisWorks Moderator david.kingham's Avatar
    2004-07
    Fort Collins, CO
    1,329
    Default 4g RAM and the /3G Switch
    So I've installed 4g of ram and added the /3G switch to the boot.ini....Everything seems to work fine, bios shows 4g, and windows shows 3.5 (which I think is normal) but if I look in the journal files for Revit it only shows 2g
    ' OPERATING SYSTEM INFORMATION:
    ' BuildNumber : 2600
    ' BuildType : Multiprocessor Free
    ' Caption : Microsoft Windows XP Professional
    ' CodeSet : 1252
    ' CountryCode : 1
    ' CSDVersion : Service Pack 2
    ' FreePhysicalMemory : 2921332
    ' FreeSpaceInPagingFiles : 7132816
    ' FreeVirtualMemory : 2056440
    ' MaxProcessMemorySize : 2097024
    ' OSLanguage : 1033
    ' OSType : 18
    ' ServicePackMajorVersion : 2
    ' ServicePackMinorVersion : 0
    ' TotalVirtualMemorySize : 2097024
    ' TotalVisibleMemorySize : 3668052
    ' Version : 5.1.2600
    ' Process affinity mask : 3
    ' System affinity mask : 3
    ' System Memory Statistics:
    ' Total RAM: 3668052 Kb
    ' Available RAM: 1742444 Kb
    ' Total VM: 2097024 Kb
    ' Available VM: 1519688 Kb
    ' Revit Memory Usage Statistics:
    ' RAM usage: 260444 Kb
    ' Peak RAM usage: 403496 Kb
    ' VM usage: 349244 Kb
    ' Peak VM usage: 367440 Kb
    The developers are looking at the problem but I thought I would check to see if any of you had any experiences with this since they take forever to respond.
    All AUGI, all the time robert.manna's Avatar
    2005-05
    Boston
    777
    Default Re: 4g RAM and the /3G Switch
    I belive that 2 is the max... I also believe that the 4 is overkill, cause Winblows will actually only use 1 of the remaining 2, but hey you're all set when they release the 64 bit version . Hopefully I'm wrong and someone else will correct me.
    -R
    100 Club mschroeder's Avatar
    Boston
    154
    There could be something wrong with your configuration. Check that you don't have a lot of memory sucking services running in the background. Revit indicates free physical memory.
    Our systems are all 4GB with 3GB switch and it has increased our stability tremendously on our large projects.
    Right now mine says: MaxProcessMemorySize : 3145600
    Certifiable AUGI Addict twiceroadsfool's Avatar
    2006-01
    4,516
    Yup...
    ' CodeSet : 1252
    ' CountryCode : 1
    ' FreePhysicalMemory : 2758340
    ' FreeSpaceInPagingFiles : 4889696
    ' FreeVirtualMemory : 3105020
    ' MaxProcessMemorySize : 3145600
    ' OSLanguage : 1033
    ' OSType : 18
    ' TotalVirtualMemorySize : 3145600
    ' TotalVisibleMemorySize : 3407356
    ' PROCESSOR INFORMATION:
    Mine see's it as well. Did you remember to reboot and select the instance of Windows that has the switch on it? We changed the ini file here so that you get the option which "versio" of XP to start up, and i just have to select the one that says 3gb in the title. Of course, the IT guy accidentally but the 3gb in the wrnog title, so make sure its the right command line that you put the switch and the title on, lol...
    My system sees 3.25, of the 4 that are installed. It might be over kill, but when we're doing model cleanup, i have three instances of Revit open, each with a 100 MB model opened. And they all fly...
    The above post is by a user not frequenting the site. Questions regarding post:
    Send to: aaron@aaronmaller.com (include text of post). Thanks.
    2004-07
    Fort Collins, CO
    1,329
    Ever had one of those "duh" moments? Somewhere along the line I got it in my head that the switch was /3G ........what a difference one letter makes, it's /3GB duhhhh
    2006-01
    4,516
    Glad you got it figured out. I have to remember to make the swich on my home rig one of these days...
  1. Switch to LT?
    By jmd1959 in forum AutoCAD LT - General
    Last Post: 2010-10-07, 09:09 PM
  2. switch Annatative On/Off
    By CadDog in forum AutoLISP
    Last Post: 2007-08-03, 09:45 PM
  3. Switch to .NET?
    By mcoffman in forum VBA/COM Interop
    Last Post: 2006-12-04, 07:43 PM
  4. Win XP Pro and /3GB switch
    By jguest in forum Windows XP
    Last Post: 2006-03-20, 09:05 AM
  5. Double switch plates and switch/outlet combos
    By christo4robin in forum Revit Architecture - Families
    Last Post: 2004-12-04, 03:23 AM
