Results 1 to 10 of 12
Thread: Stretch box on both sides equally
    2004-07
    Baton Rouge, Louisiana
    247
    Default Stretch box on both sides equally
    we have a block that we use for labeling vav boxes, i would like to make it to where the box on both ends stretch at the same time. the reason i want to make stretchable is , that the engineers do not realize that we do not have much room with HVAC drafting. i have tried look at the white pages on dynamic blocks, just can't find the information i am looking for, any help would be grateful.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,333
    Default Re: Stretch box on both sides equally
    Can you post a picture or a drawing with the block inserted? Someone may be able to point you in the right direction then.
    13,627
    Hi
    See if the following threads offer any help...
    stretch 2 directions with 1 grip?
    Dynamic Block file sharing anyone? - contains some Dynamic Block examples that Stretch both sides at the same time.
    Have a good one, Mike
    2005-05
    64
    I think a similar discussion is also going on in this current thread: http://forums.augi.com/showthread.php?t=50116
    2004-07
    247
    Here is the block i was asking about. it has been inserted into a drawing called help. i looked at all the tips, but still can not figure it out. please help. this drawing is autocad 2007
    Retired Forum Staff Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    Although the answer was on the other thread as well, here is the solution to your problem.
    Hope it works for ya.
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
    2004-07
    247
    thanks the block works great. what i need to know is the steps on to make other blocks to work. i read the other links, just can not seem to find the info that i am looking for.
    2005-06
    1,828
    Quote Originally Posted by vtmiii
    step 1: create box
    step 2: make box into block
    step 3: Open BE and create linear parameter from one ond of box to the other.
    step 4: set grips to 0 - make sure that chain actions is set to no as it is not necessary here.
    step 5: stretch action on one side of box connected to stretch grip. angle offset is 0, distance multiplier is 1
    step 6: second stretch action for other side of box. when it asks you to select parameter point to associate with action, select main grip. When it asks for first and second corners of stretch frame, do so for the other side of the box. select appropriate lines.
    step 7: angle offset to 180 and distance multiplier to remain at 1.
    step 8: stand on chair and do a jig cuz you're DONE.
    [SIGPIC][/SIGPIC]
    LOVED the one grip with the 180 Angle Offset. I have attached a block.
    2004-07
    247
    i cann't believe someone else responded to this post a couple of years after the orignal post. since then i have gone and made many dynamic blocks
  1. Stretch Equally 2 sides
    By Mac Demer in forum Dynamic Blocks - Technical
    Last Post: 2012-02-13, 01:04 PM
  2. All Families Are NOT Created Equally
    By seandburke in forum Revit Architecture - Families
    Last Post: 2009-12-15, 01:10 AM
  3. Array from center equally two directions
    By jnoon in forum Dynamic Blocks - Technical
    Last Post: 2009-09-08, 12:12 PM
  4. Equally dividing mullions
    By pligkid20 in forum Revit Architecture - General
    Last Post: 2008-03-01, 03:14 PM
  5. Trying to Stretch a hatch in a Dynamic Block with the Stretch parameter
    By hnewman in forum Dynamic Blocks - Technical
    Last Post: 2007-11-05, 09:34 PM
