Thread: DWG file compression containing 3D Solids
    2006-08
    5
    Question DWG file compression containing 3D Solids
    Is there a way in ACAD 2007 to compress your dwg files?
    The drawing i made is 6 MB, existing of 3D solids only and part of a library i'm putting togehter. So this file (a fence/guardrail with spanded metal) is too large for multiple use in 1 single drawing.
    I noticed that the framework of the fence is 300k, so the problem is the spanded metal. I made it out of a extruded rectangle, and afterwards i subtracted a pattern of panes.
    Can it be compressed and still be used normally in ACAD2007?
    TIA
    Joris
    2001-03
    13,499
    Default Re: DWG file compression containing 3D Solids
    Hi
    See if the following helps...
    ID: TS1062770 - Reducing the size of 3D DWG files
    Have a good one, Mike
    0,0,0 The Origin
    8,029
    If it is acceptable and possible to use a material definition to represent the expanded metal instead of geometry (if you are producing renderings), that will reduce the file size.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
  1. Import 3D Max file to AutoCAD as solids
    By mmccarter in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-10-22, 07:31 AM
  2. Dwg file compression
    By JosSmos in forum AutoCAD Map 3D - General
    Last Post: 2006-11-06, 11:22 AM
  3. Compression for AVIs
    By sifuentes in forum Revit Architecture - General
    Last Post: 2005-07-26, 03:02 PM
  4. Compression Programs
    By pashley in forum Revit - Rendering
    Last Post: 2004-04-13, 03:35 PM
