Results 1 to 10 of 11
Thread: Field Justification - Fit a field into an area
    2015-11
    9
    Question Field Justification - Fit a field into an area
    Does anyone know if there is a way to "Fit" a field into an area, or are the only choices, "left", "right", "middle", etc.?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Field Justification - Fit a field into an area
    A field is not a standard AutoCAD object. It must reside in one of the objects that are for text (TEXT, MTEXT, ATTDEF). It therefore must follow the justifications for those types of objects.
    Retired Forum Staff Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    Quote Originally Posted by Opie
    I've also had some co-workers ask me about this specifically in relation to Dynamic Blocks.
    When a DB is flipped, the field stays with the same orientation (if it started as left justified, it stays that way after the flip). Some people ask if it can be made so that the justification is flipped as well. The long and short of it is NO. You can't flip justifications on fields in Dynamic Blocks. Reason: Read Opie's comment above. And because of that, it does not adhere to the same standards that text entities do.
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
    2002-01
    jUSt Here (a lot)
    9,106
    Quote Originally Posted by max.sabre
    ...it does not adhere to the same standards that text entities do.
    Rico,
    I'm Since it is part of the text / mtext / attdef object, it must follow the justification of the text / mtext / attdef object. To change the justification, you would need to change the justification of the text / mtext / attdef object.
    2005-06
    1,828
    Rico,
    Well yeah ... I know. But for some reason, in DBs it doesn't work that way.
    If you flip a text object, it flips justification as well. Right?
    But when you flip a field (when it's placed in a text object) - the justification does not flip.
    Here is an example of what I mean ....
    Type in any text.
    Then flip the block and type in more text. a longer string, maybe. then you'll see why i say that. Maybe you can figure out what's going on?
    [SIGPIC][/SIGPIC]
    2005-06
    1,828
    Type in any text.
    I forgot to add .....
    if you take the flipped / weird text block and reset and flip again, the justification flips ok.
    so so weird ....
    [SIGPIC][/SIGPIC]
    2015-11
    9
    Thumbs up Re: Field Justification - Fit a field into an area
    I found that when I inserted the field into single line text (not multiline text), I was able to justify the text to "fit" by changing its properties. Thanks so much for the help.
    2002-01
    jUSt Here (a lot)
    9,106
    so so weird ....
    That is a Dynamic Block issue. Whole 'nother can o' worms.
    2005-06
    1,828
    well, yes and no. hehe. wanna answer anyway? :P
    [SIGPIC][/SIGPIC]
    2002-01
    jUSt Here (a lot)
    9,106
    With a question. Why is it not a Dynamic Block issue? You can only get a flip action in a DB. Apparently the edit of the attribute is not being correctly calculated when the DB is flipped. It cannot happen unless the DB is flipped. Sounds like a DB issue to me.
  1. Field.....field category, only two options left the rest are gone?
    By Bgy Niugan in forum AutoCAD Civil 3D - General
    Last Post: 2012-04-24, 07:12 PM
  2. Replies: 2
    Last Post: 2007-04-20, 05:40 AM
  3. DText Justification shifts when adding a Field
    By Hammer.John.J in forum AutoCAD Fields
    Last Post: 2006-06-16, 02:23 PM
  4. Adding an area field
    By MikeM4OSU in forum AutoCAD Fields
    Last Post: 2005-05-06, 06:38 AM
  5. Field justification
    By rgorman in forum AutoCAD Fields
    Last Post: 2004-09-22, 03:56 PM
