Results 1 to 6 of 6
Thread: temporary dimensions
    2005-06
    2
    Question temporary dimensions
    when i create a new wall, door or window i can not read the temporary dimension the text size is so small. my screen size is 1024x768 but my co worker is 1600x1200 and he can read his fine, his text size is 10 larger??????
    please help
    thanks
    2006-10
    Arlington, Texas
    596
    Default Re: temporary dimensions
    My guess is that you have your view scale set differently. The text dynamically scales with the view scale, so if you have 1"=100' your text will be huge and if your scale is set to 3" = 1' your text will be tiny. (Given that you're actually looking at the same area on your screen each time). If your section tags and any other annotations are equally tiny then you know this is the problem.
    On a similar vane, sometimes my temp dimensions are off the screen because I am zoomed in close to an object. This makes it particularly difficult to model certain objects with finer details. It is supposed to dynamically move to always be visible I though. Anyone else notice this as well?
    2005-07
    Somewhere in the BIM world
    3,792
    Temporary dimensions arenot realted to view scale. There's no way to modify those.
    2005-06
    2
    thank you
    i have just opened the project on a different computer and the problem has disappeared
    the problem only seem to happen on this on this one project.
    all new project the problem dos not happen
    2005-07
    3,792
    Did you update your video drivers ? What kind of video card do you have ?
    2006-10
    Arlington, Texas
    596
    Quote Originally Posted by dhurtubise
    After reading this, I got a little curious because I had seen some scaling of temporary dimensions occur and assumed it was related to view scale. I did a little testing and it actually happened that the text remained a constant size unless I zoomed in and out. When I did, the text shrunk or blew up. It started at a standard size at whatever zoom I was at when I activated the temp. dimensions. So, I updated my video drivers and Viola! they now stay a constant size no matter what I do. Very strange behavior...Very strange indeed...
  1. No Temporary Dimensions
    By raddis in forum Revit Architecture - General
    Last Post: 2007-05-16, 04:46 AM
  2. Temporary Dimensions
    By Brian Myers in forum Revit Architecture - General
    Last Post: 2007-05-11, 12:56 PM
  3. temporary dimensions
    By marcknapen in forum Revit Architecture - General
    Last Post: 2006-11-30, 02:09 PM
  4. Temporary Dimensions
    By JTF in forum Revit Architecture - General
    Last Post: 2005-01-12, 12:56 PM
  5. Temporary dimensions
    By Martin P in forum Revit Architecture - Wish List
    Last Post: 2003-05-09, 02:16 PM
