Results 1 to 10 of 12
Thread: Clean up outside drawings for internal use as Xrefs etc
    2004-08
    13
    Default Clean up outside drawings for internal use as Xrefs etc
    I am sure this subject has been addressed before as I am sure everyone has run across it at one time or another . . .
    When receiving furniture & equipment drawings from vendors that we would like to x-ref into our floor plans and these drawings have blocks nested within blocks and objects are not always drawn color by layer. We would like to see these objects as a light-weight line so the only way to get the color to something our plotter recognizes it is to explode, and explode, and explode. sometimes these files can be 5-10MB so you imagine the pain
    Is there a quicker and simpler way to do this?
    All AUGI, all the time Avatart's Avatar
    2004-06
    here, watcha gonna do?
    926
    Default Re: Clean up outside drawings for internal use as Xrefs etc
    Quote Originally Posted by joe.n
    What I have always done is to download vendor drawings, hack and bash the into shape, then make them available to my users. Keeps your drawings consistent and looking good and the file size down.
    ^^ Ceci n'est pas une post ^^
    I could stop if I wanted to andy.manninen's Avatar
    2005-12
    @ _ork
    304
    What i have always done is either SHRINKWRAP (avail. through the right click menu) the objects to get clean polylines, or explode, purge and OVERKILL the drawing. Changing everything to a generic layer and so forth.
    Be careful or regapps (Registered Applications) as they can add to a file size dramatically. To purge regapps run a command line purge by typing "-purge" on the command line, selecting R for regapps, * for all, and N for confirm name. I couldn't find my post on regapps in a previous thread so i can't link to that, but the synopsis was: Regapps are virulent in nature, any drawing that even XREFs a DWG that has regapps in it will be "infected" and from then on contain the regapps unless purged. The only way to purge regapps is with third party software or by running the command line purge and selecting R for regapps. I use ACAD 2005, i don't know if you can do this with LT or not. Hope it helps!
    :Cheers:
    Andrew Manninen
    CAD Manager
    The man who smiles when things go wrong has thought of someone to blame it on. - Robert Bloch
    150700
    3,421
    I don't think SHRINKWRAP is a vanilla AutoCAD command
    2004-06
    926
    Quote Originally Posted by BrenBren
    It's not, that's an ADT command.
    0,0,0 The Origin
    8,060
    Quote Originally Posted by andy.manninen
    :Cheers:
    -purge / regapps does work in LT2007, I don't know about earlier LTs.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2001-03
    13,499
    <SNIP>
    Hi
    If you have not tried the forum search facility, give it a try... as you will find numerous threads that have already dealt with this very topic eg
    Take a look at the links found in the following post...
    RE: Change colours of everything in a drawing, including Blocks, Xrefs etc
    Have a good one, Mike
    2004-06
    926
    Quote Originally Posted by jaberwok
    Purging Regapps is new to 2007, use the long hand technique pre-2007.
    2001-03
    13,499
    Quote Originally Posted by carl_hd_collins
    Hi
    Sorry that is not true...
    AutoCAD 2005 introduced the ability to Purge RegApps from the command line version of _.-Purge
    2004-06
    926
    Quote Originally Posted by Mike.Perry
    Hi
    I didn't know that! Obviously....
  1. Sharing drawings with xrefs with other companies without grief
    By gj65235 in forum AutoCAD Tips & Tricks
    Last Post: 2008-03-27, 10:23 AM
  2. Replies: 14
    Last Post: 2006-10-04, 06:22 AM
  3. Command to clean up bad drawings
    By jacep in forum AutoCAD General
    Last Post: 2006-08-28, 05:14 PM
  4. Clean up Xrefs to help improve drawing performance
    By cadmecheng in forum AutoCAD LT - General
    Last Post: 2006-05-10, 09:58 PM
