Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: "An error has occurred while drawing the contents of this window. This window . . ."
    I could stop if I wanted to Dean Camlin's Avatar
    2003-04
    Westminster, MD, USA
    315
    Default "An error has occurred while drawing the contents of this window. This window . . ."
    . . . shall be closed."
    I have a file in which I am receiving this error message whenever I try to open certain views. I'm certain it is due to a corrupted AutoCAD drawing that has been imported into these views. Before I contact customer support (and get charged for the call), does anyone know of a way to delete the bad import without opening the view?
    Dean R. Camlin, AIA, LEED AP
    The CADSmith Chad Smith's Avatar
    2003-05
    Brisbane, Australia
    1,729
    Default Re: "An error has occurred while drawing the contents of this window. This window . . ."
    It seems to be an error that has happened to a few of us already, see here.
    Revit Arch. Wishlist Mgr. Wes Macaulay's Avatar
    2003-05
    Vancouver, BC CANADA
    3,344
    Turn OpenGL off then give it another go
    Wes Macaulay LEED AP
    Teck Construction LLP
    Revit 2014 x64 | Win7 x64 | nVidia GT 650M
    Tell Adesk what you think!
    All AUGI, all the time DanielleAnderson's Avatar
    2004-06
    Mostly in Mom-land
    704
    Quote Originally Posted by Wes Macaulay
    Yep - I was getting that error all the time with OpenGL open. I turned it off and all is well now.
    2005-07
    3,220
    I'd try leaving OpenGL on and reduce the hardware acceleration first. It typically cures the problem and you don't sacrifice the improvements that OpenGL offers.
    2003-04
    315
    Thanks! That seems to work.
    2005-12
    72
    I only turn the open GL when I using a lot 3D views or doing renderings, you can notice the difference on speed, otherwise at least on my computer floor plans with open GL are slower and also I get the same message as you did.
    2003-04
    Scotland
    1,576
    I get this message quite regularly - If I do a "close all hidden windows" the try it again, it always works the second time, in my case it seems to be related to having too many open windows in the background. I am half planning to create a mini macro using the strokeit software I use to automatically close all hidden windows every time I execute maybe a zoom window command.
    2003-04
    315
    In this case, Martin, it really does seem to be isolated to the OpenGL setting. Since I turned that off I haven't suffered any more of those pesky messages.
    AUGI Addict Andre Baros's Avatar
    2003-12
    Point of no return
    1,604
    I've also found this to be OpenGL related, but updating video drivers solves the problem and lets you keep the OpenGL. At least that was the case with the latest nVidia drivers.
  1. 2012: An error has occurred while drawing the contents of this window. This window shall be closed.
    By cvill017964006 in forum Revit Architecture - General
    Last Post: 2011-12-10, 05:50 PM
  2. Error closes Revit: An error has occurred while drawing the contents of this window.
    By chasen_forever in forum Revit Architecture - General
    Last Post: 2010-05-07, 03:38 PM
  3. An error has occured while drawing the contents of the window....
    By Dave Lewis in forum Revit Architecture - General
    Last Post: 2007-06-19, 08:32 AM
  4. How To: Print an area of a drawing by "Window"
    By Scott Davis in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-09-24, 02:09 PM
