Results 1 to 10 of 11
Thread: Draw Viewport on correct Layer then switch back to original Layer
    2006-02
    22
    Red face Draw Viewport on correct Layer then switch back to original Layer
    Hello
    Is it possible to alter the 'Single Viewport' button macro to change layer to "VPort", allow the user to draw the viewport, then change the layer settings back to previous.
    Regards
    Steve
    All AUGI, all the time madcadder's Avatar
    Back in the Bay; Looking for work.
    979
    Default Re: Draw Viewport on correct Layer then switch back to original Layer
    yes... What version?
    2006-02
    22
    Hi Todd
    Autocad 2007
    2005-09
    Reading, PA
    214
    Just go into the .cui, copy and edit the command, then reassign it.
    2006-02
    22
    Hi
    What command will I have to assign within the macro, I can change the layer to viewport and am then able to draw my viewport, but I do not know how to revert back to layerp at the end.
    Appreciate your help
    Cheers
    Steve
    0,0,0 The Origin
    8,027
    ._Layer ._Previous should do it.
    Otherwise it's some lisp - set a variable equal to the current layer name at the beginning and restore it later.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2006-02
    22
    Cheers for your help everyone
    The end product was the following
    -la;s;viewport;;$M=$(if,$(eq,$(getvar,vpmaximizedstate),1),^C^C_-vports,$(if,$(eq,$(getvar,tilemode),1),^C^C_-vports _si,^C^C_-vports));\\LayerP
    2006-02
    22
    Question Re: Draw Viewport on correct Layer then switch back to original Layer
    The above scenario does not seem to have the same impact on polygonal viewports, can someone advise me on achieving the same result for this
    Cheers
    Steve
    2001-03
    13,499
    Hi Steve
    Please note I have *moved* this thread from the AutoCAD General forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
    2001-03
    13,499
  1. Replies: 2
    Last Post: 2012-01-08, 02:04 PM
  2. Correct Layer
    By rhayes.99001 in forum ACA General
    Last Post: 2008-05-21, 06:59 PM
  3. Replies: 4
    Last Post: 2006-12-11, 05:34 PM
  4. Replies: 8
    Last Post: 2006-10-28, 09:47 PM
