Thread: Does Design Review offer better font handling capabilities than DWF Viewer?
    2006-02
    74
    Default Does Design Review offer better font handling capabilities than DWF Viewer?
    Does Design Review offer better font handling capabilities than Viewer? I've had problems with capturing fonts, which, I believe, is because Autocad will not capture copyright protected fonts. The only way I can be assured that fonts will travel with my dwf files is to set font handling to capture all as geometry. This makes the file larger. The file also opens and prints slower. There has to be a better way.
    13,656
    Default Re: Does Design Review offer better font handling capabilities than DWF Viewer?
    Hi
    The following blog posts by Scott Sheppard may offer some help / guidance...
    Avoiding AutoCAD DWF font woes
    DWF display obeys ClearType setting
    When does ClearType apply to my DWF?
    Have a good one, Mike
    2006-02
    74
    Thanks Mike.
    The first artical confirms my fear the this is a copyright issue. I guess I need to find an architectural font that isn't copyright protected. Capture all as geometry makes the dwf file too large, slows down publishing and slows down Viewer, Composer and Ddesign Review too.
    I could stop if I wanted to scott.sheppard's Avatar
    2005-07
    Scottsdale, Arizona
    239
    I am not a fan of capture as geometry. I think the text looks choppy. The font engines of most operating systems do a better job of rendering text.
    Autodesk Design Review and the Autodesk DWF Viewer are the same in many ways. Autodesk Design Review adds capabilities like markup, measurement, and batch printing. But for things like file loading and rendering, we code once and use twice!
  1. Replies: 4
    Last Post: 2010-08-11, 02:02 PM
  2. Pdf's from recent AUGI ATP course on DWF design review/viewer
    By PEWAUKEEJOHN in forum Design Review - General
    Last Post: 2007-12-03, 10:09 PM
  3. Design Review appears to be slow to open when compared with DWF Viewer
    By robert.1.hall72202 in forum Design Review - General
    Last Post: 2007-03-06, 06:45 PM
  4. IE7 Hotfix: Autodesk Design Review 2007 and Autodesk DWF Viewer 7.0
    By Mike.Perry in forum DWF Viewer - General
    Last Post: 2006-10-28, 04:24 AM
  5. IE7 Hotfix: Autodesk Design Review 2007 and Autodesk DWF Viewer 7.0
    By Mike.Perry in forum Design Review - General
    Last Post: 2006-10-27, 02:45 PM
