Results 1 to 10 of 12
Thread: Place Radius dimension displays "Enter dimension text" at command line
    2004-12
    55
    Post Place Radius dimension displays "Enter dimension text" at command line
    I'm having problems with the Radius Dimension command. When I pick the arc to dimension I get a prompt on the command line "Enter dimension text <25>". I don't want this option. I just want it do dimension the 25' radius arc. What setting do I need to change?
    Thanks, Todd
    0,0,0 The Origin
    8,570
    Default Re: Place Radius dimension displays "Enter dimension text" at command line
    What happens if you just press Enter ?
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    Quote Originally Posted by jaberwok
    and if you don't get the ' foot mark automatically, check the dimension formatting options.
    13,656
    Question Re: Place Radius dimension displays "Enter dimension text" at command line
    Quote Originally Posted by todd.80290
    Hi
    Is the Text option of the _.DimRadius command somehow being automatically run, as that would cause the display of Enter dimension text <25> ?
    Have a good one, Mike
    2004-12
    55
    When I hit enter it places the radius dimension into the drawing, but I have 100 of these to do and hitting enter at this prompt takes alot of extra time.
    How do I tell if the 'text' option is automatically being run? Where can I change this?
    Todd
    13,656
    Hi
    Once the _.DimRadius command has finished running review the AutoCAD Command Window [F2].
    How are you running the _.DimRaduis command in the first place eg
    * Pull-down menu.
    * Toolbar.
    * Tool Palette.
    * Typing at the AutoCAD command line.
    * etc.
    2004-12
    55
    Mike,
    The command line looks like this:
    Command: _dimradius
    Select arc or circle:
    Specify dimension line location or [Mtext/Text/Angle]:
    I'm using the toolbar button to start the command.
    Todd
    0,0,0 The Origin
    8,570
    The macro associated with the button should read - ^C^C_dimradius
    It's viewable in the cui editor - right-click a blank toolbar area and pick "customize".
    2004-12
    55
    Yes, this is exactly what the command looks like. Any suggestions on how to get rid of the prompt for the dimension?
    Thanks, Todd
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Change the macro. Unfortunately, I can't help you there. I don't deal with macros much.
  1. Replies: 10
    Last Post: 2010-03-11, 12:49 PM
  2. Dimension Text "Home" Location
    By signalbass in forum Revit Architecture - General
    Last Post: 2010-02-22, 09:36 PM
  3. Dimension "Text Override"?
    By jsteinhauer in forum Revit Architecture - Families
    Last Post: 2008-01-31, 01:31 AM
  4. To allow the command "Dimension" in the Modeling tab Design Bar
    By luigi in forum Revit Architecture - Wish List
    Last Post: 2005-05-25, 07:37 AM
  5. Place the text centered on dimension line
    By gravelin in forum Revit Architecture - Wish List
    Last Post: 2005-01-09, 06:12 PM
