Results 1 to 10 of 12
Thread: Shortcut for Rightclick "Hide Annotation in View"?
    2004-05
    Auckland, New Zealand
    340
    Default Shortcut for Rightclick "Hide Annotation in View"?
    Hi guys
    doing alot of Rightclick "Hide Annotation in View", and want to know if there is a shortcut to this? so i can select a whole lot of stuff and then do the command?
    Cheers
    Dwane Stairmand
    I could stop if I wanted to Adam Mac's Avatar
    2004-06
    Darwin NT
    319
    Default Re: Shortcut for Rightclick "Hide Annotation in View"?
    Hi Dwane,
    I assume you know about the "view graphics" (VG) dialogue box?
    Most things can be turned on or off in one go from there.
    Not sure if that answers your question?
    Adam.
    2005-07
    3,220
    I don't think it does...he' trying to turn off visibility of certain instances of elevation or section tags or gridlines....no there's no shortcut unfortunately. You have to do them one by one. This has been brought up several times and I'm sure it's on the wishlist.
    AUGI Addict truevis's Avatar
    2004-07
    Massachusetts, USA
    1,186
    Can someone explain the relationship between Scope boxes and section/elevation annotation?
    AUGI Addict luigi's Avatar
    2003-05
    Royal oak, Michigan
    1,509
    Quote Originally Posted by truevis
    It's as simple as if a section or elevation is set to a scope box, i.e. scope box "A", the crop region of the section or elevation will match scope box "A" crop region. So nothing directly related to the annotation...just the crop region....but grids retain the visibility as well...so grid in scope box A will not show up in a scope box B view...
    Did I help?
    100 Club s.messing's Avatar
    2006-08
    Cambridge, MA
    174
    Quote Originally Posted by d.stairmand
    Hi guys
    Cheers
    Dwane Stairmand
    Try clicking something and typing VH (that will hide the category of the object selected, an action parallel to Hide Annotation in View). If you want to hide more than one category, highlight the objects and then type VH. It's an easy way to turn off the visibility of a category (functions identically to typing VV or VG and then finding the category and then clicking off the checkbox, which is a lot slower).
    Buena Suerte,
    Esteban
    Active Member modulor's Avatar
    2004-06
    Los Angeles
    88
    Quote Originally Posted by s.messing
    Buena Suerte,
    Esteban
    That's a great tip, but it hides the whole category, not just a selection of instances.
    -Erik
    2006-08
    Cambridge, MA
    174
    Quote Originally Posted by modulor
    -Erik
    I am sad because you are right. I was excited because I had an easy fix, but alas, the easy fix is really not an easy fix and therefore I am sad.
    Does this mean that a wish list item would be to be able to Hide Multiple Annotation(s) in View?
    The only other option I could think of (if you wanted to turn off multiple Section Markers at the same time) is:
    Highlight just the ones you want to turn off. Then, go to properties and choose Hide at Scales Coarser Than. Set the scale to something higher than the actual scale of the drawing. This does not work for things such as Elevation Markers, but would be a way to turn of a whole bunch of Section Markers at the same time.
    2006-03
    London, UK
    810
    I know it's not much faster, but you can hit H once you've done the right-click to immediately Hide In This View.
    2006-10
    Cape Town
    94
    It seems to me that in Revit you can do almost anything...slowly. Everything has a workaround and is on a wishlist somewhere. The time it takes to switch off a category by entering the vg dialogue box and scrolling around is ridiculous (but thanks for the tip, s.messing. It will definitely help!) Switching off certain objects in a category is equally slow. (Is there perhaps a way of getting them back without trying to locate the invisible line on plan?) I think one should be able to create custom subcategories for everything.
  1. "detail view" vs "floor plan" in callouts
    By shane.249457 in forum Revit Architecture - General
    Last Post: 2011-03-08, 08:29 PM
  2. Replies: 3
    Last Post: 2007-10-23, 09:06 PM
  3. AutoCAD 2007 ignoring "Start In" shortcut property
    By sthedens in forum AutoCAD General
    Last Post: 2007-01-29, 02:44 PM
  4. When using the Shortcut menu - Unknown command "AI_DIM_TEXTHOME"
    By Shane.Miller in forum AutoCAD General
    Last Post: 2006-12-09, 07:17 PM
