Thread: line weight #1 at 1/8" scale line weight too thick and not .003"
    100 Club 3dsketcher's Avatar
    2001-02
    new york, NY
    114
    Default line weight #1 at 1/8" scale line weight too thick and not .003"
    anybody has the same problem? for some reason it does not allow me to make a generic model lineweight to be thin.
    2005-09
    Perth Australia
    467
    Default Re: line weight #1 at 1/8" scale line weight too thick and not .003"
    Have you also setup the Line Weights under the Settings Menu?
    Rob
    2001-02
    new york, NY
    114
    thanks. i have that already. at 1/8", pen no 1 is .003"
    i found a workaround though. i realized i can override linework by object so what i did is i cycled (tab) through the object until i had highlighted the whole screen then just used thin lines from the linework option
  1. Line Weight Scale & Color Dependant Layers & CTB
    By Ykang.236078 in forum AutoCAD General
    Last Post: 2011-04-21, 09:54 PM
  2. Projection/Surface Line Color Override negates Line Weight
    By nosten in forum Revit Architecture - General
    Last Post: 2008-09-30, 07:57 PM
  3. I need help with line scale and weight
    By alcx112 in forum AutoCAD General
    Last Post: 2008-09-30, 05:50 AM
  4. line weight vs line style
    By belyo in forum Revit Architecture - General
    Last Post: 2006-10-11, 02:23 PM
  5. How do you change the line weight of Property line?
    By Richard McCarthy in forum Revit Architecture - General
    Last Post: 2004-11-17, 03:13 PM
