Results 1 to 10 of 15
Thread: Dynamic Pile Caps
    Active Member Animal's Avatar
    2006-08
    Lancashire, UK
    81
    Default Dynamic Pile Caps
    I've just created my first set of 'proper' dynamic blocks (i.e. not just changing visibility states) of pile caps.
    Each block has 2 visibility states, plan & elevation and pile sizes range from 200mm dia to 600mm dia in 50mm increments. The cap depth ranges from 700mm to 1m and the pile inset from 75mm to 125mm into the cap.
    The 3 pile cap took forever to get working, but I got there eventually.
    NOTE: NOW UPDATED TO INCLUDE REFERENCES & DYNAMIC CO-ORDINATES FOR THE PILE CENTRES..
    Retired Forum Staff Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    Default Re: Dynamic Pile Caps
    Quote Originally Posted by ti598
    Looks like there was a lot of thought and effort placed into making them. I'm sure someone will give your blocks a good home. Congratulations and good work!
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
    2006-08
    Lancashire, UK
    81
    Cheers dude, Yeah a lot of work and a fair bit of swearing, especially for the 3-pile block - that must have taken a good 4 hours to get right. I kept getting half way through and then every time I tried to add another stretch action it kept telling me I'd picked an invalid action & created a loop even if no other actions were selected so I had to keep erasing all the actions and starting over.
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    the 'loop' thing happens when you select both action & parameter under an action that for some reason isn't compatible. as a rule of thumb, don't include other actions under actions for a 'mostly' trouble-free DB.
    S&D DB Sharing Forum
    2006-08
    Lancashire, UK
    81
    I have just updated these blocks (see first post) and have a quick question.
    The 3 pile cap keeps reverting to a 'custom' size when you alter the lookup value and the base point goes wonky - you have to click the size a couple of times to get it right. Can anyone shed any light on this for me?
    Cheers
    Paul
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    Cheers
    Paul
    Does Rico's explanation help?
    2006-08
    Lancashire, UK
    81
    Quote Originally Posted by Opie
    Kind of, but I can't figure out why the basepoint doesn't go to the right place until the SECOND time you click on the size.
    The basepoint should be at 2/3rds the vertical length of the pile cap. Is there a way to get the block to work this out itself? I have had to draw all 9 sizes, get the distance of each size and add that to the lookup table.
    2005-06
    1,828
    What happens if you regen after the first click?
    [SIGPIC][/SIGPIC]
    2006-08
    Lancashire, UK
    81
    Nothing happens after a regen - the basepoint stays in the wrong place. If you keep swapping sizes, the basepoint wanders allover the place. It's like the first click sets the size of the pad and the second click puts the basepoint in the right place and I can't work out what's causing it.
    2005-06
    1,828
    Do you have your basepoint included in any actions that might be causing it to move? (Aside from the desired move action?)
    [SIGPIC][/SIGPIC]
  1. 2012: Revit Pile Caps
    By jbailey896133 in forum Revit Structure - General
    Last Post: 2013-05-10, 06:16 PM
  2. 2013: Nested Shared Parameters Wth Pile Caps
    By russell987619 in forum Revit Structure - Families
    Last Post: 2013-03-05, 03:49 PM
  3. 2012: Piles/Pile Caps
    By mikeh996011 in forum Revit Structure - General
    Last Post: 2011-09-05, 03:55 PM
  4. Miscellaneous - Dynamic Pile Cut (Imperial & Metric)
    By Rico in forum Dynamic Blocks - Sharing
    Last Post: 2010-05-18, 08:35 PM
  5. Pile, Caps & Gradebeams
    By freeme in forum Revit Structure - Wish List
    Last Post: 2009-10-25, 04:47 PM
