Thread: Wall join problem - curtain wall & gyp bd partition.
    2005-12
    Hartford, CT
    394
    Default Wall join problem - curtain wall & gyp bd partition.
    I have a particular problem with a wall join condition on my current project. I have an interior gyp bd. wall intersectiong with an exterior curtain wall. I want the gyp. bd. partition to butt up against the inside face of the curtain wall mullion. But the gyp. bd. wall joins to the curtain wall center line, not the mullion.
    Tim
    2004-08
    Syracuse, NY
    631
    Default Re: Wall join problem - curtain wall & gyp bd partition.
    Mine seems to work without any difficulty. I am using release 9.1.
    I could stop if I wanted to cek's Avatar
    2004-07
    Tucson, Arizona, USA
    224
    Although this is an old thread I was able to graphically address this problem by spliting the gyp bd. wall at the face of the curtain wall frame. Then by using the hide element function you can get rid of the offending portion of the wall that wants to bury itself inside the curtain wall frame.
  1. 2014: Curtain Wall Corner Join
    By Hexdown in forum Revit Architecture - General
    Last Post: 2015-02-16, 08:09 AM
  2. Join Curtain Wall mullions
    By DaveP in forum Revit Architecture - General
    Last Post: 2007-11-02, 02:14 PM
  3. Join Curtain Wall Panels
    By raddis in forum Revit Architecture - General
    Last Post: 2006-10-13, 09:29 PM
  4. Partition wall rendering problem
    By alext in forum Revit - Rendering
    Last Post: 2006-03-29, 07:48 PM
  5. Join wall and curtain wall
    By E-Key in forum Revit Architecture - General
    Last Post: 2005-12-13, 08:28 PM
