Results 1 to 6 of 6
Thread: Demo a ceiling grid?
    2001-12
    1,713
    Default Demo a ceiling grid?
    I have two ceiling grid demolition issues I am trying to address, and as far as I can tell, there is just no way to deal with a grid ceiling and demolition.
    The first is just taking a whole area of grid to be demolished. Then a new header will go in between existing grid and the demo'd area, and a new gyp ceiling will be added. But I can't seem to demo a ceiling grid at all, nor can I split the ceiling into to areas, so I can demo one.
    The second issue is probably a wishlist item. I have a bunch of existing 2X2 grid with existing 2X4 lights. I am going to remove all the existing lights, put some new ones back where the old ones where, put some new ones in new locations, and repair the grid at some locations where old lights came out. Graphically, I need to be able to show as demo the small 2' sections of grid where the new lights are going in to new locations. I also need to show as new the 2' grid sections where a light has been removed and the existing grid has been patched.
    Also, even though my ceiling was inserted in a Phase Existing view, the grid still shows up black in all views. The walls are showing up right, and indeed in section the ceiling shows up right. But in the Ceiling plan it shows up black, be it a new ceiling, a demo ceiling or an existing ceiling.
    Any thoughts?
    Gordon
    All AUGI, all the time archjake's Avatar
    2003-08
    Tucson, AZ
    531
    Default Re: Demo a ceiling grid?
    I've been going back to the phase that the ceiling was created. Revise it so that it is split into separate ceilings. Then you can demo the one(s) (read - pieces) that you are trying to demo. Not the best approach, but it works.
    If you play long enough you will see that some elements that cut a ceiling do show that the part that is cut from the family will show up as demo'd.
    It would be nice if the pattern that makes up a 2x4 or 2x2 ceiling will change to a dashed pattern.
    Needless to say - ceilings don't work well with the phasing tools.
    Jake Boen, Architect
    www.InPlaceArchitecture.com
    www.BIMproductivity.com
    Tucson, Arizona
    2001-12
    1,713
    Quote Originally Posted by archjake
    The problem is that it is very specifically the dashing of the grid that we need. The fact that is shows up right in section but not RCP is pretty lame. I will be posting this to the wishlist, as tracing the entire ceiling grid in drafting lines is both daft and the only way to get a deliverable that can be built from. Aiii!
    Best,
    Gordon
    2002-02
    St. Louis, MO
    4,688
    Quote Originally Posted by gordon.price
    Best,
    Gordon
    Best solution I can offer (as we've run into this as well....) is to export just the grid ceilings to AutoCAD and then import the grid back into Revit as model linework on the surface of the ceiling. This can be exploded and then the linework demo'ed.
    I've played with an intermediate demo phase where I can show the walls as existing, the ceiling as "new" in a demo phase an override the object style, but that yields poor background exports for consultants.
    Yes it is a pita.
    Don't drink the Kool-Aid...
    Aaron Rumple, AIA
    NavisWorks Moderator david.kingham's Avatar
    2004-07
    Fort Collins, CO
    1,329
    Here's a demo pattern I created
    Active Member L Wood's Avatar
    2007-07
    California, Sacramento
    70
    Thanks for sharing!
  1. Demo Ceiling
    By artworx01 in forum Revit Architecture - General
    Last Post: 2011-09-07, 11:21 PM
  2. Showing Ceiling Demo
    By dbaldacchino in forum Revit Architecture - General
    Last Post: 2008-02-06, 06:55 PM
  3. Demo ceiling grid
    By Kirk Bricker in forum Revit Architecture - General
    Last Post: 2005-03-07, 03:17 PM
  4. Matching ceiling grid to ceiling rendering
    By Nevine in forum Revit - Rendering
    Last Post: 2004-11-27, 05:55 AM
  5. Matching ceiling grid to ceiling rendering
    By Nevine in forum Revit Architecture - General
