Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 61
Thread: KeyboardShortcuts.txt -- what's your strategy?
  1. #41
    AUGI Addict DaveP's Avatar
    2002-12
    St Paul, MN
    1,569
    Default Re: KeyboardShortcuts.txt -- what's your strategy?
    We've gone the other way. Instead of one-character shortcuts, I've been adding three characters. Since we're training more people now, I'm opting for easy-to-remember as opposed to quick:
    "TAG" menu:"Drafting-Tag-By Category"
    "SEC" menu:"View-New-Section"
    "RAM" menu:"File-Relinquish All Mine"
    Also BB to toggle the Project Browser
    I also see Aaron has NS for New sheet. I've been using that one & love it for when you have to add the Engineering sheets. Just create the first sheet & change the Sheet number. Then bang on your keyboard NSNSNSNSNSNSNSNSNSNSNSNSNS.
    BAM, a dozen sheets. You still need to change the name, but it sure beats
    View.. oops, pull-down closed....
    View... damn...
    View... New Sheet - finally!
  2. #42
    I could stop if I wanted to jspartz's Avatar
    2015-12
    361
    The NS for New Sheet doesn't work so good if you have more than one titleblock family loaded, because a window comes up asking which one you want. We always have more than one because of our normal titleblock and then our cover sheet.
    Here's one I made and found to be quite helpful.
    XX for Modify
    The reasoning is that sometimes I'm just too lazy to keep moving my hand up and down the keyboard constantly hitting escape twice, when all my other commands are at my fingertips already. So, XX is like exit out of the command for me. It's quick and simple.
  3. #43
    All AUGI, all the time jbalding48677's Avatar
    2003-05
    Irvine, CA
    765
    Interesting thread...
    We use "XX" for close hidden windows because the X in the upper right corner in all windows apps closes the window. Easy to remember anyway.
    - JB
  4. #44
    2015-12
    361
    I thought of doing that as well, but ending up using CW for close windows and XX for modify. That way I don't have to use Escape (or accidentally hit the F1 key which brings up help) at all.
  5. #45
    2007-10
    Portland, OR
    69
    Question Re: KeyboardShortcuts.txt -- what's your strategy?
    I can't get F10 to work as a keyboard shortcut in Windows XP. Is that in conflict with some Windows shortcut?
  6. #46
    All AUGI, all the time Elmo's Avatar
    2005-04
    South Africa
    959
    Try not to use F Lock buttons to for short cuts. They are usually assigned for normal windows commands and as you said will give you a conflict.
  7. #47
    2004-06
    Memphis TN area
    7,048
    Is there any way to make a shortcut for Paste Align - View/Level/Same Place, etc.?
  8. #48
    2005-07
    Somewhere in the BIM world
    3,792
    Quote Originally Posted by patricks View Post
    Open the keyboard shortcut fole
    ; "" menu:"Edit-Paste Aligned-Current View"
    ; "" menu:"Edit-Paste Aligned-Same Place"
    ; "" menu:"Edit-Paste Aligned-Pick Level Graphics"
    ; "" menu:"Edit-Paste Aligned-Select Levels by Name"
    ; "" menu:"Edit-Paste Aligned-Select Views by Name"
  9. #49
    2007-01
    11
    I just installed Revit Architecture 2009 on my laptop (Vista Home Premium ).
    I noticed the "KeyboardShortcuts.txt" was not in the "C:\Program Files\Revit Architecture 2009\Program" folder. Has anyone else run into this?
    I can not customize any shortcuts right now even if I copy a "KeyboardShortcuts.txt" into this folder.
  10. #50
    Member nwitte's Avatar
    2004-12
    7
    I just checked and found the KeyboardShortcuts.txt file to be located in the typical location in 2009:
    C:\Program Files\Revit Architecture 2009\Program\KeyboardShortcuts.txt
    Revit 2009 (Installed from network deployment)
  1. keyboardshortcuts
    By bernd.eichner in forum Revit - API
    Last Post: 2009-07-01, 02:30 PM
  2. RST 2010 KeyboardShortcuts.txt
    By David Harrington in forum Revit Structure - General
    Last Post: 2009-05-19, 07:27 PM
  3. keyboardshortcuts
    By JH75 in forum Revit Structure - General
    Last Post: 2009-04-30, 12:50 AM
  4. KeyboardShortcuts
    By dom51 in forum Revit Architecture - General
    Last Post: 2008-06-10, 03:10 PM
  5. edit keyboardshortcuts
    By mwittens83539 in forum AutoCAD General
    Last Post: 2005-05-18, 05:05 PM
