Results 1 to 9 of 9
Thread: Array appears to go the other way (backwards) when used from the command line
    2015-08
    Menasha, WI
    74
    Default Array appears to go the other way (backwards) when used from the command line
    I have a drawing that was sent from another company (aren't all the problems stemmed from this?).
    Anyways the array that should be going in the Y direction is going in the X, and the X arrays to the Y. What setting am I missing?
    It works if I use the dialog box, but not from the command line.
    angdir = 0
    angbase = 0
    Thanks in Advance,
    Darin
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Array appears to go the other way (backwards) when used from the command line
    Is your UCS set to World?
    2015-08
    Menasha, WI
    74
    You gotter otter.
    2015-08
    Menasha, WI
    74
    Maybe I should have been more clear, UCS is set to World, so that's not the problem.
    2003-10
    San Francisco CA
    1,190
    So you're saying if you want an array 3 in X direction and 5 in Y direction you enter 5 rows and 3 columns and it draws it the opposite of that?
    Is there a reason you don't want to use the dialog box or are you just curious as to why it's not working?
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
    13,656
    Question Re: Array appears to go the other way (backwards) when used from the command line
    Hi
    Is it possible to post the DWG file that exhibits the behaviour you have described above...
    Have a good one, Mike
    2015-08
    Menasha, WI
    74
    I can post the drawing (never done it before) after removing some stuff from it.
    As for the previous response, yes if I want 3 Y, 5 X that is exactly what happens, 5 going Y, 3 going X.
    I'm an old timer (yeah almost 40!!!) who work the mouse with one hand and keyboard with the other and there are still several commands that are quicker than dialog boxes. (pause for the audible gasp here). So going to the dialog box was my second option to see what the heck was going on.
    And always curious.
    All AUGI, all the time Richard.Kent's Avatar
    2001-01
    Albuquerque, NM, USA
    622
    It seems that the command line -array will honor the snapang setting while the dialog ignores it. Set SNAPANG to zero in your drawing.
    Last edited by Richard.Kent; 2006-11-17 at 10:19 PM. Reason: hit the wrong button and it posted before I was done.
    2015-08
    Menasha, WI
    74
    Way to go Kent!!!! Thank you for your answer to this one. We're now off and running.
    Thanks
    Darin
  1. Text backwards after Mirror Command
    By gfreddog in forum AutoCAD General
    Last Post: 2008-02-05, 12:50 PM
  2. Input @ command appears to be slow
    By nw-surv3 in forum AutoCAD LT - General
    Last Post: 2007-02-14, 06:32 PM
  3. Replies: 4
    Last Post: 2007-02-14, 03:03 PM
  4. Replies: 4
    Last Post: 2006-05-09, 08:57 PM
  5. SaveAs appears on the command line
    By tmorrow91 in forum AutoCAD General
    Last Post: 2005-12-16, 01:49 PM
