I am in the process of converting a mass amount of .dgn files drawn in Microstation to AutoDesk .dwg files. Thankfully I figured out how to use the .csv file in Microstation 8 and batch convert the drawings with the correct layer styles, lineweights, fonts, etc. Now I am at the point where I need to match the converted drawings with our DWG Layers. I can open each individual file and use the laytrans command to match layers with a pre-made drawing standards file. But since there are hundreds of drawings to convert, this would be a very long and tedious process. So now I am trying to write a Script that will run everytime AutoDesk is opened; this Script should run the laytrans command so that when the drawing is open we have the layers matched to our current layer states.
Since I am fairly new with ScriptPro and using Lisps this process is going very slow. If anyone could offer a script to do this or send me in the right direction I would be grateful...
