Results 1 to 7 of 7
Thread: Run routine and get "; error: bad argument type: (or stringp symbolp): nil"
    2005-08
    378
    Cool Run routine and get "; error: bad argument type: (or stringp symbolp): nil"
    Guys,
    Can someone assist by pointing out my error.
    I have put it all in single lined into the command line and it works. Run the routine and get "; error: bad argument type: (or stringp symbolp): nil"
    Not sure what it is, expecting something real silly.
    Regards
    Stephen
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    Default Re: Run routine and get "; error: bad argument type: (or stringp symbolp): nil"
    Yes, to you
    (setvar "CMDECHO" 0 )
    your code
    (setvar "CMDECHO" 1 )
    : ) Happy Computing !
    kennet
    2005-08
    378
    Cool Re: Run routine and get "; error: bad argument type: (or stringp symbolp): nil"
    Ha ha hah,
    Thank you kennet. Like I said, it would be something stupid.
    Regards
    Stephen
    2005-08
    378
    Kennet,
    Maybe you can assist ?
    Does anyone know how to open visual lisp editor with lisp ? (what command if any ?)
    Can anyone explain to me what the different modes do with the ".fas" compiler ?
    mode
    The compiler mode, which can be one of the following symbols:
    st Standard build mode
    lsm Optimize and link indirectly
    lsa Optimize and link directly
    Regards
    Stephen
    2015-08
    263
    Quote Originally Posted by stephen.coff
    Kennet,
    Stephen,
    Try
     (c:vlide)
    Regards
    Abdul Huck
    2002-05
    1,707
    Kennet,
    Can anyone explain to me what the different modes do with the ".fas" compiler ? . . .
    Regards
    Stephen
    Standard mode is sufficient for most application.
    The optimize mode can reduce your executable file size by eleminating internal functions and variable symbols.
    The link mode can optimize your program's speed by substituting references to functions' names with a direct reference to the function's compiled body.
    You will find a lot of more information under the [F1] button inside Vlide (c:vlide)
    kennet
    2005-08
    378
    Abdulhuck,
    Sorry for the long delay, chirstmas always has things crazily busy.
    Q. How do I close vlide, and thank you (c:vlide) opens perfectly.
    Regards
    Stephen
  1. Error: bad argument type: FILE "r"
    By shell2712 in forum AutoLISP
    Last Post: 2013-09-04, 08:29 PM
  2. Replies: 8
    Last Post: 2012-01-28, 10:01 PM
  3. VBALOAD error: bad argument type: stringp nil
    By jpaulsen in forum AutoLISP
    Last Post: 2011-11-09, 05:52 PM
  4. Replies: 4
    Last Post: 2009-05-22, 05:21 AM
  5. Replies: 3
    Last Post: 2006-12-11, 08:31 PM
