Results 1 to 10 of 11
Thread: DVIEW in AutoCAD LT 2007?
    2006-05
    139
    Default DVIEW in AutoCAD LT 2007?
    I noticed that Autodesk didn't include the DVIEW command in AutoCAD LT 2007 ( ). Therefore, I can't use DVIEW --> TWIST and therefore...
    Does anyone know of a way to work around this problem without changing the UCS? Maybe a lisp? (I have LT Extender) I have been using DVIEW as part of MVSETUP and now this routine doesn't work.
    Any help is much appreciated.
    0,0,0 The Origin
    8,569
    Default Re: DVIEW in AutoCAD LT 2007?
    UCS[enter]
    Z[enter]
    90 (required angle)[enter]
    plan[enter]
    [enter]
    UCS[enter]
    P(revious)[enter]
    John B
    2006-05
    139
    Quote Originally Posted by jaberwok
    UCS[enter]
    Z[enter]
    plan[enter]
    [enter]
    UCS[enter]
    P(revious)[enter]
    Thanks for that. I will use it if there is no other way. I was actually thinking if there was a way to "import" the DVIEW command, either with lisp or any other way.
    Any ideas?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,296
    Quote Originally Posted by Inferno6919
    Any ideas?
    You can't use LISP in LT without a 3rd party add-on that allows LISP to run.
    0,0,0 The Origin
    8,569
    Any ideas?
    It'll work as a macro or as a script - assuming you always want the same angle.
    John B
    2006-05
    139
    Quote Originally Posted by Opie
    I have LT-Extender which allows Lisp in LT
    2006-05
    139
    I would like it to work with all sort of angles, not a fixed one. Same as DVIEW and MVSETUP.
    If there are any ideas, please fire away.
    Thanks
    0,0,0 The Origin
    8,569
    Thanks
    Ask the user for the angle and store it (as a real ?)
    Run the macro above and insert the variable value at the appropriate point.
    Sorry, I'm not good enough to code it off the top of my head.
    John B
    2005-06
    in the upper right corner
    3,050
    Thumbs up Re: DVIEW in AutoCAD LT 2007?
    We have some people in our office running 2007LT and used to use the dview command.
    Boy were they bumming when they found out they removed dview!!
    To help them out, I searched this thread I took jaberwok's suggestion.
    I wrote them a couple quick scripts to do the job. They just wanted to rotate a view in 90 degree incriments and be able to go back to world. But don't really want to have to use the ucs commands.
    This one is named USC_90.scr
    ucs
    z
    90
    plan
    zoom
    e
    This one is called UCS_WORLD.scr
    ucs
    world
    plan
    zoom
    e
    Wicked simple, and it helped them get the job done.
    I'm assuming you could assign a button to this, but don't know for sure.
    Ted
    ____________________________________________________________________ ________________
    Windows 7 Professional
    AutoCAD 2017 - REVIT 2017 - Inventor Professional 2015 (when I can)
    2005-03
    I live "high in the misty Highlands"
    Angry Re: DVIEW in AutoCAD LT 2007?
    Hello,
    I've just upgraded from 2004LT to 2007LT and I always use the DVIEW command but have just realised that it's missing! I like to specify the angle on screen rather than typing in a specific number. Why did they remove this feature??
  1. Unable to open regular AutoCAD 2007 from Mechanical 2007
    By irchrismm in forum AutoCAD General
    Last Post: 2010-07-15, 08:05 PM
  2. LT 2007 - Missing DVIEW
    By lli in forum AutoCAD LT - General
    Last Post: 2007-10-19, 02:53 PM
  3. AutoCAD 2007 and AutoCAD LT 2007 Service Pack 2 is available
    By Mike.Perry in forum AutoCAD General
    Last Post: 2007-04-09, 08:42 PM
  4. AutoCAD 2007 and LT 2007 - Custom menus load randomly...
    By robdg in forum AutoCAD CUI Menus
    Last Post: 2006-11-17, 03:57 AM
  5. Replies: 2
    Last Post: 2006-05-30, 05:58 PM
