Results 1 to 8 of 8
Thread: Sharing Tool Palettes on the network from AutoCAD LT
    2004-10
    Yorkshire, UK
    402
    Exclamation Sharing Tool Palettes on the network from AutoCAD LT
    I would like to share my AutoCAD LT tool palettes on our network.
    This seems simple enough, I just save my palettes on the network and change the tool palettes location on everyone elses machines, and it works except the order of the palettes, and palette grouping is not transfered to the other machines.
    I don't want to export the palettes and groups and set them up on every other machine, is there a simple way to do this?
    13,656
    Default Re: Sharing Tool Palettes on the network from AutoCAD LT
    Hi "ajd"
    Please note I have *moved* this thread from the AutoCAD General forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
    13,656
    Hi
    If Tool Palettes work the same in AutoCAD LT as they do in AutoCAD you need to look at / investigate the use of .AWS files.
    A little more information on .AWS files can be found in the following post...
    RE: Tool palettes don't appear the same on all stations
    Have a good one, Mike
    2004-10
    Yorkshire, UK
    402
    Unfortunately AutoCAD LT (2006) doesn't use profiles, although there is a default AWS file in the support folder for each user.
    I have tried copying all of the files in the profile folder to an identical LT machine, and the palette grouping and order still doesn't transfer.
    I could stop if I wanted to johan d's Avatar
    2006-01
    Belgium
    287
    I did it the folloxwing way (don't need profiles for this)
    - Set up the toolbars as you want them on your local PC
    - Copy the toolpalettefolder (all it's content) to a network drive
    - set your toolpalette file location to the network folder
    - set your collueges toolpalette file location to the network folder.
    Give everyone but you read access to that network folder to prevent unwanted modification to your toolpalettes by others.
    2004-10
    Yorkshire, UK
    402
    Thanks Johan,
    I have got this far, but unfortunately, this doesnt transfer the Palette grouping or order/size of the icons to the other PCs
    2006-01
    Belgium
    287
    No that's true. Groups and order do not transfer to other machines.
    We don't use groups for that reason, we just create "new toolpalette" to make different "areas"
    Does this help you?
    13,656
    Quote Originally Posted by ajd
    Hi
    Below extract comes directly from Matt Murphy's - The Productivity Power of Palettes Revealed" - AUGI CAD Camp course...
    If you want to maintain the order of tool on shared palettes, you'll need to move the original profile (.AWS) file to the local machine. As long as the profile exists locally with the same name as the original profile, the .AWS file will maintain the order of the tools based on the most recent locations.
  1. 2012: Eureka guide for sharing AutoCAD tool palettes
    By hreuvers in forum AutoCAD Customization
    Last Post: 2013-01-19, 03:49 PM
  2. Sharing Tool Palettes with other AutoCAD 2006 users, tools not in same order
    By sschwartz85916 in forum AutoCAD Customization
    Last Post: 2007-03-06, 03:34 PM
  3. Sharing Tool Palettes with other users on a network
    By austec in forum AutoCAD Customization
    Last Post: 2007-02-23, 07:59 AM
  4. Sharing Tool Palettes with other users in AutoCAD 2006
    By JDRBWA in forum AutoCAD Customization
    Last Post: 2007-02-14, 06:40 PM
  5. Sharing Tool Palettes via the network
    By z66 in forum AutoCAD Customization
    Last Post: 2006-10-14, 02:52 AM
