Thread: Simple, yet....Layouts, Page Setups, & New Users
    Active Member chill's Avatar
    Twangtown USA
    92
    Question Simple, yet....Layouts, Page Setups, & New Users
    Good persons,
    PRESENT METHOD ( I didn't say the best)
    I initially setup our template file(s) with the most inexperienced user in mind when we started using Acad Mech 2000 Power Pack.
    As we use paper space layouts, I had a layout tab named A, B, & D for each of our paper sizes used , you guessed it, A, B, & D sizes! I saved a page setup in each layout named just like the above.
    _______
    DING!!!!!!!!!
    We actually could get by with one layout in the template file and choose page setups with the needed paper size, plot style, etc. defined within the page setup?
    Is that the way you 'do' your template files?
    Clint Hill
    Thrive in '05
    2001-03
    13,499
    Default Re: Simple, yet....Layouts, Page Setups, & New Users
    Hi
    Yep.
    Might want to have a read of the following thread -
    page setup
    Have a good one, Mike
    2001-10
    Arizona
    2,337
    I advise all clients to create the templates to contain
    ALL required layout tabs with named layouts.
    This makes it very easy to add additional layouts
    through page set-up new layout from template function.
    The best practice might be several tmplates with the required
    layouts in them for their specific purposes, so that there
    are fewer layouts to pick from in each.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    Forum Manager, Administrator Ed Jobe's Avatar
    Turlock, CA
    4,776
    Your needs may vary, but here, multiple layouts create more work. If you have objects in paper space (e.g. titleblocks), then you have to maintain them in each layout. You can't make a change in one and have it update all the other layouts. Our template contains the titleblock for the size of the final dwg. In the case of multiple sizes, multiple templates. You can however print any template to any size by scaling. For that, you have multiple page setups in the template. For example, we standardize on D size for most of our dwgs, some A. I have templates for both sizes. The D template has page setups for all the plotters/printes we have (5) and all the paper sizes we use (A,B,D). So it has 15 page setups, with a naming convention of "SheetSize - Printer". Just pick the name wich specifies the combination you want and print. This is far easier than chaning the tile block in each layout. Also, this is not the situation where each layout contains different "drawings" of the same model. But having different layouts of the same "drawing" just for plotting does not make sense to me.
    C:> ED WORKING....
    2001-10
    Arizona
    2,337
    Quote Originally Posted by eljobe
    Your needs may vary, but here, multiple layouts create more work. If you have objects in paper space (e.g. titleblocks), then you have to maintain them in each layout. You can't make a change in one and have it update all the other layouts. .
    Good point Ed, and the reason behind the use of an XREF for ones titleblock for the active
    project!
    Be your Best,
    Michael Farrell
  1. Page Setups
    By brent.burgess.182044 in forum Dot Net API
    Last Post: 2008-11-07, 03:26 PM
  2. Page setups not working for other users
    By ymarchitect in forum AutoCAD Plotting
    Last Post: 2006-04-01, 07:58 AM
  3. Missing Page Setups in Page Setup Override
    By whurd.61597 in forum AutoCAD Sheet Set Manager
    Last Post: 2005-06-15, 08:41 PM
