Results 1 to 6 of 6
Thread: Andersen Frenchwood Doors
    Revit Family Guy adegnan's Avatar
    2003-04
    DeForest, WI
    633
    Wink Andersen Frenchwood Doors
    OK. Here are the Andersen FWH and FWO 400-series doors with type catalogs, muntins, etc.
    New functionality here is that the jamb depth is set by instance parameter. The default is set to 5 1/2" (for Dow Intelligen Wall construciton) so you may want to change the default to 6 1/2" or 7" or whatever you use. But the important part is this will keep the door inset in your brick walls so that the installation flange and jamb depth are realistic-- they will be at the back of the brick, not out flush with the brick.
    You can set these instance parameters individually and then you should be able to create a window schedule that will post the jamb depth for you.
    I'll probably update the windows with this functionality sometime as well.
    100 Club m_cahoon14336's Avatar
    2004-02
    Jonesboro, AR
    186
    Default Re: Andersen Frenchwood Doors
    Abe, Thanks for the doors. I am still working on the project that required these doors, so I will put them to good use. They look great!!!
    Colquhoun
    Wrong is wrong even if everyone is doing it; right is right even if no one is doing it. - St. Augustine
    All AUGI, all the time mlgatzke's Avatar
    2003-05
    Ankeny, Iowa, USA
    761
    Man Abe, you 'da man!
    By the way, I could sure use a casement with the colonial and prairie grid muntins (just like your fixed family). And, if it isn't too much I could use doubles, and triples too.
    I've been messing around with creating my own family (from Campbell's family), but haven't grasped nested families quite yet.
    I could stop if I wanted to tonyisenhoff's Avatar
    Milwaukee, Wisconsin
    424
    Dude - You need to contact Andersen and get paid for all this work!
    2003-04
    DeForest, WI
    633
    I have some contacts there... I should talk to them and see what they have to say! Of course, if they know I've already done the work... who knows! Our local Andersen rep is active on the NAHB-Remodelor's Council so I see him often.
    2003-05
    Verona, WI
    7
    Nice job Abe-I look forward to hearing more at the next user group meeting
  1. Andersen Arch Window
    By Doug in forum Revit Architecture - Families
    Last Post: 2005-06-27, 03:20 PM
  2. Andersen French Doors??
    By SHARRY in forum Revit Architecture - Families
    Last Post: 2004-06-15, 09:58 PM
  3. Updated Andersen available on RUGI
    By adegnan in forum Revit Architecture - General
    Last Post: 2004-04-22, 10:07 PM
  4. Andersen Windows
    By nrenfro in forum Revit Architecture - General
    Last Post: 2004-01-07, 02:31 PM
  5. Andersen Windows
    By bucksy in forum Revit Architecture - General
    Last Post: 2003-11-22, 10:03 PM
