Hi mohobrien,
I'm not sure my answerd would help you,but for the best solution try this code
[MAPPLOT]^C^C (if(not c:Norm_DWFPlot250)(load "D:/bla/bla/NORM_DWFPLOT250.LSP")));Norm_DWFPlot250;
mohobrien
Actually this isn't really a lisp question but lisp is part of it so here's posting.
I've got a mickey mouse batch plotting routine for dwf files and want to put the command on a button macro. Before I load and run the lisp part of the macro, I want to run an acmap command that loads various variables into memory for my batch plotting. This is what I've got in the button.
^C^C_MAPPLOT^C(if(null c:Norm_DWFPlot250)(LOAD(FINDFILE "NORM_DWFPLOT250.LSP")));Norm_DWFPLOT250
all on the same line of course.
First time through, this is the command line output:.
Command: _MAPPLOT
Command: (if(null c:Norm_DWFPlot250)(LOAD(FINDFILE "NORM_DWFPLOT250.LSP")))
BROWSEFORFOLDER
Command: Norm_DWFPLOT250
Second time through:
Command:
Command: _MAPPLOT
nil
So everything appears to be working. But it's not. MAPPLOT doesn't run. I can't find a way to close MAPPLOT through the macro. From the command line, you can close it with escape, or c but I can't figure how to do it in the macro.
Any ideas or threads to point to? I can't find a solution.
