Results 1 to 7 of 7
Thread: Drawing Scales in Layouts
    2006-02
    4
    Default Drawing Scales in Layouts
    Could someone point me in the right thread that discussed how drawing scales are made on layouts? I'm get pretty confused when a new layout sheet is setup on an existing drawing and i have to scale the new layout sheet, especially for drawings i did not make from scratch.
    13,656
    Default Re: Drawing Scales in Layouts
    Hi
    Could you please supply some additional information, as currently I am not fully understanding the query at hand. Sorry.
    In the meantime, see if the following offers any assistance / help...
    AUGI HotNews article -> TIPniques: Mind the Gap - September 2005
    And associated thread -> Sept '05 - TIPniques: Mind the Gap
    AUGI HotNews article -> Techniques: The Power of Page Setups - October 2005
    And associated thread -> Oct '05 - TIPniques: Power of Page Setups
    Have a good one, Mike
    I could stop if I wanted to macwizzy06's Avatar
    2005-09
    Nigeria, Africa
    245
    Did the links above help?
    I believe that when you review drafts, a precise scale is not always important. You can use the Scaled to Fit option to plot the view at a size that fits the paper. AutoCAD fits the height or width of the drawing to the corresponding height or width of the paper.
    However if you are required to indicate a layout scale, be careful as 2 scales are involved:
    (1) the overall drawing layout, which usually is scaled 1:1, based on the paper size. Most designers make objects at their actual sizes in mm or inches, so this shouldn't be a problem.
    (2) the scale of the model itself, which is displayed in the layout viewport(s). The scale in the viewport represents a ratio of the paper size to the size of the model in the viewport. When you plot, you can choose the unit type, inches or millimeters, under Paper Size and Paper Units. For example, if mm is selected, entering 1 under Plotted mm and 10 under Drawing Units produces a plotted drawing in which each plotted millimeter represents 10 actual millimeters. This is the scale factor that should appear on your legend or layout title block.
    Hope it helps because this is beginning to sound like an ATP class.
    2006-02
    4
    2
    Thanks Wisdom, you pretty much hit it on the head for me! Was initially difficult for me to understand by mere reading but once i opened acad, it all became clear as if i was talking to the software programmer. It worked!
    Mike's links are very valueable too, it exposed me to a whole new world of acad with lots of possibilities. Thanks guys, gracias!
    2006-02
    4
    What's ATP? Augi Training Program? Why don't you teach want to teach ATP?
    2005-09
    Nigeria, Africa
    245
    Quote Originally Posted by stun_hands
    Now i'm blushing!
    Yeah right! After much consultation, I found that infomation on acad help menu and thought it'd be useful to you. I'm glad it helped, as I wasn't also sure of what you were asking! Mike has always been very handy with great links! I personally saved most of his links above in my favorites folder for future reference. Do not forget to browse around the forums here every now and then.
    Cheers!
    2005-09
    Nigeria, Africa
    245
    I'll definitely teach as soon as i have enough knowledge to offer others. I'm practically just learning stuffs now.
  1. One drawing from many layouts
    Last Post: 2013-02-08, 09:46 AM
  2. excessive annotations scales in Layouts
    By mk144390 in forum AutoCAD Annotation
    Last Post: 2011-04-08, 06:58 AM
  3. How do you move layouts from drawing to drawing?
    By javankoehn in forum CAD Management - General
    Last Post: 2007-12-14, 04:19 PM
  4. Annotation - Drawing Scales
    By jm.pearson105333 in forum Dynamic Blocks - Sharing
    Last Post: 2006-02-16, 05:06 PM
  5. Multiple Drawing Scales
    By nfuller in forum AMEP General
    Last Post: 2004-07-05, 12:47 AM
