Thread: Specialty equipment visibility...
    100 Club FWSchreck's Avatar
    177
    Default Specialty equipment visibility...
    Hello:
    I'm creating a library of medical equipment families for our office. Much of this equipment is wall mounted, often placed at heights above the standard cut plane.
    My process has been to create 3D geometry for use in 3D and elevation views, then use symbolic linework to represent the geometry for plan and ceiling views.
    My problem is that the symbolic linework does not display in plan for objects inserted above the cut plane. How can I get this linework to display, regardless of the cut plane? I'd rather not use plan regions.
    2005-01
    Milwaukee, Wisconsin
    636
    Default Re: Specialty equipment visibility...
    Quote Originally Posted by fred.3541
    It's a really dumb work-around but until I figure out a better way, I drew invisible model lines on the Ref Level and locked them to that level. This means that even though the object is not within the view range, it "thinks" it is.
    Did this for a bunch of accessory families this way. Not elegant but it works and it's quick. Attached image is a diaper changing station that I mounted at 8'-0" AFF for demo purposes.
    Hope this helps.
    2002-02
    St. Louis, MO
    4,695
    Hello:
    Add an invisible model line that extends down to the cut plane....
  1. 2012: Specialty Equipment Family disapearing
    By madyb in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2012-05-04, 04:20 PM
  2. Specialty Equipment family
    By nazeer.kutty in forum Revit Architecture - General
    Last Post: 2008-09-12, 03:55 PM
  3. Specialty Equipment Families
    By mjward1 in forum Revit Architecture - Families
    Last Post: 2008-06-05, 01:57 PM
  4. Specialty Equipment Tag
    Last Post: 2008-04-07, 01:14 PM
  5. In-place Specialty Equipment problem
    Last Post: 2007-03-26, 11:26 PM
