I was told that this was good and I should share. So here goes.
This addresses the problem of room objects not staying from one phase to another. I have requested that they add a created and demo phase to Room objects and hopefully this gets fixed soon.
Lets say you have rooms in Phase one and these rooms will also be in phase two. One way to get them into phase two is to copy and paste aligned. However what if you change the names in phase one and want them to change in phase two, to the same.
1 Take phase one view with room objects tagged and ‘duplicate with detailing’.
2 in the duplicated view, go to VV and turn off all categories visibility except for room tags and room objects.
3 Take your phase two view and place it on a sheet at appropriate scale
4 take the duplicated phase one view and place it over the phase two view at the same scale
It should snap align. Don’t forget that this can put a kink in your schedules, but you can always duplicate that too. Play around with it and use it as needed, I hope this helps and is useful to others.
Scott
TRO Jung|Brannen
