I have a couple of different barrel-vaulted roofs that I created by extrusion, but the behavior of the roof properties doesn't seem consistent.
On the first roof I created, I was in my South elevation, and used Grid C as my work plane. The roof properties shows -6" as the start offset, and 31'-0" for the depth. The resulting roof starts 6" towards my viewpoint in elevation, and then extends back away from my viewpoint 31 feet.
On the second roof, I was also in the South elevation, and used Grid B as my work plane. I wanted a similar roof, but longer. On this roof, I had to change the offset reference to positive 6", and have it extend negative 211 ft. to make it extend back away from my viewpoint, in the same direction as the other roof.
So what is the deal here? Both roofs extend away from my work plane in the South Elevation, but on one I had to make the Extrusion End parameter a positive value, and the other one I had to make it a negative value. Thoughts?
