Results 1 to 6 of 6
Thread: Change Layer colors to Plot gray on a few Layouts
    100 Club andrewp's Avatar
    2003-06
    147
    Default Change Layer colors to Plot gray on a few Layouts
    okay AUGI-Guru's... i have a floor plan in model space, and it is used thru out several layout tabs (pages)... in a couple of the pages, i would like to change the color of the floor plan layer (plot in gray)... how can i do this?
    thanks in advance...
    Drew
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    6,836
    Default Re: Change Layer colors to Plot gray on a few Layouts
    You could use a layer state for that layout. Of course, you would need to remember to restore it for that layout and return the layers back to normal for the other layouts.
    If using external references, just change it for that drawing.
    2003-06
    147
    can i have a drawing reference part of itself?
    Drew
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,233
    Quote Originally Posted by andrewp
    Could you rephrase the question? What do you want to do in this second question? You can't have a circular xreference.
    AutoCAD Civil3D 2013
    Gig 'Em, Aggies!
    Never attribute to malice that which can be adequately explained by stupidity, but don't rule out malice
    2003-06
    147
    well, the floor plan that i am using is basically the drawing that I'm working in... the layout tabs will represent individuals sheets that reference the floor plan drawn in model space... with in certain sheets, like plumbing and electrical, i would like to subdue the floor plan by using a different color... when plotted, the floor plan will print grey, while specific lines will stand out... how can this be achieved with out too much trouble...
    i wondered if i could reference the floor plan to create this affect... but, as you pointed out it would be a circular reference... any ideas?
    Drew
    I could stop if I wanted to ekubaskie's Avatar
    2001-12
    Anchorage, Alaska
    324
    You could create separate page setups for the layouts, that use different CTB/STB files and are set to display plot styles.
  1. printer plotting gray in colors
    By cwjean76 in forum AutoCAD Plotting
    Last Post: 2008-09-24, 01:29 PM
  2. Printing Gray colors
    By Martin Figlarz in forum Revit - Plotting/Printing/Exporting
    Last Post: 2007-06-20, 09:04 PM
  3. LISP to change layer colors to random colors
    By mtubbs in forum AutoLISP
    Last Post: 2007-04-27, 05:39 AM
  4. Layer Colors change in Paperspace
    By MikeM4OSU in forum AutoCAD General
    Last Post: 2006-02-07, 06:59 PM
  5. Compare layer colors to pantone colors
    By gandre in forum AutoCAD LT - General
    Last Post: 2005-11-18, 12:32 PM
