Results 1 to 10 of 16
Thread: Hold down Shift key to deselect Objects not working
    100 Club smooth shoes's Avatar
    2006-11
    Backwoods
    126
    Default Hold down Shift key to deselect Objects not working
    When I select objects, I used to be able to hold down the shift button and add or remove objects. I can not do this now for some reason. Does anybody know how to turn this setting on or is there a variable somewhere that I am missing? Thanks in advance
    Gary
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Hold down Shift key to deselect Objects not working
    I believe you are looking for the PICKADD variable.
    AUGI Addict Railrose's Avatar
    Abilene, TX
    1,181
    Also, some verticals such as Raster Design have an option to change the behaviour of shift+left click. If you change this setting, it will change how AutoCAD will allow the de-select option.
    Give people a job worth doing, the tools to do it, recognition of a job well done & get out of the way.
    2006-11
    Backwoods
    126
    It's not pickadd. Thanks for the reply though.
    If I have 5 objects, i select 3 of them, i want to select one more and deselect another, I can hold down the shift button and select the object that i want removed, and then go back and select only the one that i missed without deselecting everything else. Does this make sense or am i way out there?
    What do you mean by verticals? I have this problem in several dwg's if that makes a difference.
    Thanks for the responses.
    Abilene, TX
    1,181
    Quote Originally Posted by gary.gentry
    Verticals are products added to AutoCAD. I use Raster Design on top of AutoCAD.
    2005-07
    2,356
    In options (on the format menu), go to the selection tab. Do you have noun/verb selection ticked? Also ensure there is not a tick in use shift to add to selection.
    2006-11
    Backwoods
    126
    Quote Originally Posted by Steve.Sanderson(UK)
    noun/verb selection is ticked, and there is not a tick in "use shift to add to selection". Thanks for the reply, though. Would it help to reboot my machine?
    2002-01
    jUSt Here (a lot)
    9,106
    It shouldn't hurt.
    2006-11
    Backwoods
    126
    Quote Originally Posted by Opie
    It shouldn't hurt.
    My company has got way too many programs on this computer and it takes forever rebooting. I was kinda hoping there was another way but oh well, we'll give it a shot.
    2006-11
    Backwoods
    126
    Well the reboot fixed the problem, but I'd still like to know what the problem was just so I know. If any of y'all have any suggestions, let me know. Thanks!
  1. Attached image and shift-deselect conflicting
    By jgrande26 in forum AutoCAD General
    Last Post: 2017-02-13, 08:19 AM
  2. Shift to Deselect doesn't work
    By dutch724 in forum Raster Design - General
    Last Post: 2015-02-27, 06:13 PM
  3. 2011: Hold Shift Key
    By rstiles in forum ACA General
    Last Post: 2011-03-17, 01:36 PM
  4. Replies: 4
    Last Post: 2007-04-17, 11:52 AM
