Thread: GIS Connection
    Member dmo1205342273's Avatar
    2005-06
    United States, Illinois
    45
    Question GIS Connection
    This may seem like a dumb question but how do I connect Civil 3D to my company's GIS database? I know how to do it through the task pane in 2007 Map 3D but would like to do it in Civil 3D so that I can make use of alignments and such. Any help would be appreciated.
    D
    2005-06
    45
    Default Re: GIS Connection
    I got it. I knew it could be done I just couldn't remember how. If anybody is curious here's how to do it. Pull up the "workspaces" toolbar. Click the drop down menu and select Map 3D GeoSpacial. Then go to view and click task pane and now your set up just like map. This however leads me to another question.
    Does anybody know of a way to disconnect the GIS data and keep it so that it's line work?
    2005-10
    80
    Quote Originally Posted by dmo1205
    If this is possible i would also like to know how.
    I could stop if I wanted to ekubaskie's Avatar
    2001-12
    Anchorage, Alaska
    324
    Assuming that we're talking about FDO-connected data here, select the linework you want and then right-click. Aside from checking objects in/out for editing, there are options to import the geometry. You may not be real happy with the results, though. I did it with GIS-style contours (where the elevation is a data field) and there was no way to get the elevation. I ended up bulk-copying the SDF file of contours into a shape file and using the older shapefile import from the Map menu.
  1. VBA Connection not available on Windows 8
    By j7linz438475 in forum VBA/COM Interop
    Last Post: 2015-10-22, 09:29 AM
  2. connection-pt.lsp error
    By td70509 in forum AutoLISP
    Last Post: 2013-06-19, 03:37 PM
  3. 2014: HSS- W connection + Plates, How to model this special connection?
    By jiangrayrui376960 in forum AutoCAD Structural Detailing
    Last Post: 2013-05-02, 10:01 PM
  4. MAKE BOLTED CONNECTION GENERATOR REMEMBER MATERIAL OF PLACED CONNECTION
    Last Post: 2012-07-02, 10:13 PM
  5. Connection Design
    By dcooper.cse in forum Robot Structural Analysis
    Last Post: 2011-07-14, 10:44 AM
