Probably a dumb question, but I can't get my head around it... I am using '06 pretty much straight out of the box. Recently, after loading a drawing from a client, the '06 startup routine changed from what it was before. Now, some sort of add-on application tries (and fails) to start every time I launch '06. After "CUSTOM" and "EXPRESS" Customization Groups load, the command line reports: "Error loading AcStandards services", and then a pop-up appears in the drawing area, proclaiming "Fail to create CommCntrClientSink object!". After OK'ing out of this dialog, the program seems to run as usual. I'm sure that some startup macro has had a line of code added SOMEWHERE, but I need to locate and purge it ASAP. Can somebody lead me in the right direction? Thanks!
