Thread: Window and Space Object Property Sets
    Moderator arcadia_x27's Avatar
    2015-10
    The 'Mill,Moncton, NB, Canada
    516
    Lightbulb Window and Space Object Property Sets
    I wonder if anyone out there in AUGI land can help me. I'm trying to careate a formula property that will calculate whether or not a room in a building (residential construction) passes lighting and ventilation code requirements. If I create formula properties under the window object that calculate the Lighting and Ventilation values based on a windows size, can I then create a formula property set under the space object that will calculate whether or not the room passes code? In short can a space object be set to include the properties from a window object that is only in that room space, will it reference the properties from every window, or will this not even work at all. And could it work if i assigned the space object to reference the properties from window objects? Any help would be much appreciated
    2003-03
    Philadelphia, PA
    2,392
    Default Re: Window and Space Object Property Sets
    I think you would need some heavy-duty [read: beyond my capabilities] programming to do what you want. Using a location property, a window can read data from a space [or area, or aec polygon], but the space can not read data from a window. Unless you only ever have one window in a space, in which case you could do the calculations in the window PSD, you can not do what you want with the out-of-the-box capabilities.
  1. 2015: Property Sets
    By arminm1988414598 in forum ACA General
    Last Post: 2015-05-28, 12:44 PM
  2. Replies: 0
    Last Post: 2011-11-17, 01:38 PM
  3. 2011: Property Sets
    By brian.rouse540440 in forum AMEP General
    Last Post: 2011-05-07, 03:29 PM
  4. Creating object to define window space
    By xzavoral in forum Revit Architecture - General
    Last Post: 2009-12-22, 02:30 PM
  5. Property Data Sets - Object Overrides
    By welk3d-cad1 in forum ACA Wish List
    Last Post: 2004-12-23, 03:17 PM
