Results 1 to 7 of 7
Thread: Excel to Revit (PDF? DWF?)
    The Silent Type Griff's Avatar
    2015-12
    Idaho
    293
    Default Excel to Revit (PDF? DWF?)
    I would like to link or import an Excel spread sheet into a drafting view to place on one of my drawings. I've read some previous posts that mentioned using pdf995 printer driver and converter. They suggested after installing the driver & converter, to print the excel file to PDF then convert that to a jpg file using the PDF995 convert routine. It that still the prefered method or is there a better way. How about DWF?
    Dave Griffith
    AUGI Addict andrewg's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: Excel to Revit (PDF? DWF?)
    There are other printer drivers you can use besides pdf995.
    As far as dwf, I don't think you can import a dwf into Revit. Your choices are dwg, dgn, dxf, jpg, bmp...
    2015-12
    Idaho
    293
    Do you know if the PDF995 driver is good or should I search to find others? If there are better ones, do you know which ones work best?
    Dave Griffith
    Revit Arch. Wishlist Mgr. Wes Macaulay's Avatar
    2003-05
    Vancouver, BC CANADA
    3,348
    PDF995 is really good. It's giving us better results than Acrobat! While it doesn't have all the formatting options of Acrobat or Distiller, the CAD output is superior to these higher priced products.
    Wes Macaulay LEED AP
    Teck Construction LLP
    Revit 2014 x64 | Win7 x64 | nVidia GT 650M
    Tell Adesk what you think!
    All AUGI, all the time cphubb's Avatar
    2003-11
    Seattle
    691
    You need to convert to a JPG or BMP to import to Revit. Print to pdf using PDF995 (great program btw) open in Photoshop and save as jpg medium compression. You can then import to Revit and I should plot well.
    2003-05
    Waterville, Maine
    1,748
    Also, while in revit, try printing to pdf using the revit pinebush driver, & then using pdf995's. Then compare file size & output.
    AUGI Addict PeterJ's Avatar
    2003-04
    London, UK
    1,948
    Look at this link for a variety of options to print direct to jpg, most seem to cost something but I imagine that the costs will be small enough to pay for themselves very quickly...
    http://www.google.com/search?hl=en&l...g+print+driver
    Pete
  1. Excel to Revit?
    By Jun Austria in forum Revit Architecture - General
    Last Post: 2010-01-28, 11:27 AM
  2. excel in Revit?
    By paul.meco in forum Revit Architecture - General
    Last Post: 2007-04-03, 04:20 PM
  3. Excel VBA to Revit
    By Mark.vB in forum Revit - API
    Last Post: 2007-03-29, 12:03 PM
  4. Excel in Revit
    By E-Key in forum Revit Architecture - General
    Last Post: 2005-05-27, 06:43 PM
  5. REVIT AND EXCEL
    By WATTSAIA in forum Revit Architecture - General
    Last Post: 2004-03-11, 04:14 PM
