Thread: LDT 2006 - Missing Partial Open and ReadOnly options from Open dialog box
    Cairo - no, not Illinois
    2,728
    Default LDT 2006 - Missing Partial Open and ReadOnly options from Open dialog box
    My File Open dialog box is missing the options on the pulldown for Partial Open and ReadOnly. Any ideas on what went haywire and how to restore the choices?
    I'm running LDT 2006 and LDT Enabled Map, and am not sure if that matters or not.
    Officially Awesome
    AUGI Director scott.wilcox's Avatar
    2001-01
    Edmonton, Alberta
    961
    Default Re: LDT 2006 - Missing Partial Open and ReadOnly options from Open dialog box
    The file may be in AutoCAD version 2000 or lower. Partial open does not work on pre-2002 format files.
    Why draw straws? Just draw one straw and array it.
    Scott Wilcox - Edmonton, Alberta
    2,728
    In this case all the drawings have either been created, or edited and saved, in LDT 2006/Map3d 2006.
    However, I believe that I've identified the issue -- on initial open at program startup, LDT will not offer any options in the dialog box for read-only or partial open. Once a drawing has been opened, even the blank Drawing1.dwg, then the additional options are available.
    Officially Awesome
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    1,901
    I've never found a way to open drawings read-only or partial open using any version of LDT. This would be very useful. Where is this at? Are you using the AECOPEN command (the one that requires you to select a project)?
    Jeff Paulsen
    2,728
    Not, not AECOpen, just the regular Open command -- and the options for partial open or read-only are _only_ available after a drawing has been opened. They are not available on initial program start-up
    The AECopen dialog does not offer the options
    Officially Awesome
  1. Options and Plot Dialog Box - Slow to open
    By thalim in forum AutoCAD Civil 3D - General
    Last Post: 2010-03-01, 08:45 PM
  2. open new dialog box missing
    By Gigliano70 in forum AutoCAD General
    Last Post: 2007-10-09, 02:23 PM
  3. AutoCAD 2006 Partial Open not working
    By pmedina in forum AutoCAD General
    Last Post: 2007-03-22, 07:49 PM
  4. Missing Open dialog box
    By a_meteni in forum AutoCAD General
    Last Post: 2006-04-21, 12:53 PM
  5. Open, Save dialog box missing
    By terencelee3 in forum AutoCAD General
    Last Post: 2006-01-11, 11:15 AM
